Update v3.4.0.beta3 +21 to v3.4.0.beta4 +37 fails, unable to create a directory
I’m trying to run the latest update of discourse via the web admin area. But it fails and shows below log:
*** Please be patient, next steps might take a while ***
Cycling Unicorn, to free up memory
Restarting unicorn pid: 43
Waiting for Unicorn to reload.
Waiting for Unicorn to reload..
Waiting for Unicorn to reload...
Waiting for Unicorn to reload....
Waiting for Unicorn to reload.....
Waiting for Unicorn to reload......
Waiting for Unicorn to reload.......
Waiting for Unicorn to reload........
Stopping 1 Unicorn worker(s), to free up memory
Stopping job queue to reclaim memory, master pid is 1201725
$ cd /var/www/discourse && git fetch --tags --prune-tags --prune --force
error: cannot lock ref 'refs/remotes/origin/ux/combined-themes-components-sidebar-links': unable to create directory for .git/refs/remotes/origin/ux/combined-themes-components-sidebar-links
From https://github.com/discourse/discourse
 ! [new branch]          ux/combined-themes-components-sidebar-links -> origin/ux/combined-themes-components-sidebar-links  (unable to update local ref)
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:211:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:88:in `block in upgrade'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:72:in `each'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:72:in `each_with_index'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:72:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:44:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:44:in `block in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/execution_wrapper.rb:91:in `wrap'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:70:in `conditional_executor'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command/base.rb:178:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor.rb:538:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command/base.rb:73:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:71:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:149:in `with_argv'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:69:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands.rb:18:in `<main>'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:74:in `require'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:74:in `block (2 levels) in replace_require'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
Spinning up 1 Unicorn worker(s) that were stopped initially
Entering the discourse app container and trying to create the mentioned dir manually also leads to an error message, as below:
root@vtdiscourse-app:/var/www/discourse/.git/refs/remotes/origin# mkdir ux
mkdir: cannot create directory ‘ux’: Invalid argument
I’m wondering about the error message as the mkdir call looks fine to me. Any hint?
I don’t know, but default question: what happens when you do ./launcher enter app from a console?
You need to do a command line rebuild. And you should also see PostgreSQL 15 update
I end up in the container. I can than e.g. run (as written above)
If I try this by running git pulland ./launcher rebuild app I end up with following error messages
root@vtdiscourse /var/discourse# ./launcher rebuild app
WARNING: Docker version 23.0.3 deprecated, recommend upgrade to 24.0.7 or newer.
x86_64 arch detected.
WARNING: We are about to start downloading the Discourse base image
This process may take anywhere between a few minutes to an hour, depending on your network speed
Please be patient
2.0.20250129-0720: Pulling from discourse/base
af302e5c37e9: Pull complete
ed49ab5c933d: Pull complete
7cb9e730d898: Pull complete
7c28a6b187b2: Pull complete
23222af7238f: Pull complete
59b87d9ed5c1: Pull complete
90d60b432298: Pull complete
d3b3135aa82b: Pull complete
94e7b594395d: Pull complete
cf15e2c89d00: Pull complete
2c0cccf9ec27: Pull complete
5d8ea2a8d564: Pull complete
020f04b42275: Pull complete
06e22604f387: Pull complete
8b0ecc579aad: Pull complete
4d577f7424c0: Pull complete
37ef4781925f: Pull complete
30d67d1af761: Pull complete
43eaf8c26af4: Pull complete
02f4cc50eabd: Pull complete
93896ee36e56: Pull complete
fadd5d615e0e: Pull complete
85f9459cb30e: Extracting [==================================================>]     749B/749B
eaddca2afacb: Download complete
f54443d29a2d: Download complete
ed6f0f133683: Download complete
3d1894dc563f: Download complete
51ca3f63c909: Download complete
b87374db2274: Download complete
failed to register layer: ApplyLayer exit status 1 stdout:  stderr: unlinkat /tmp/node-compile-cache/v22.13.1-x64-efe9a9df-0: invalid argument
Unable to find image 'discourse/base:2.0.20250129-0720' locally
af302e5c37e9: Pulling fs layer
ed49ab5c933d: Pulling fs layer
7cb9e730d898: Pulling fs layer
7c28a6b187b2: Pulling fs layer
23222af7238f: Pulling fs layer
59b87d9ed5c1: Pulling fs layer
90d60b432298: Pulling fs layer
d3b3135aa82b: Pulling fs layer
94e7b594395d: Pulling fs layer
cf15e2c89d00: Pulling fs layer
2c0cccf9ec27: Pulling fs layer
5d8ea2a8d564: Pulling fs layer
020f04b42275: Pulling fs layer
06e22604f387: Pulling fs layer
8b0ecc579aad: Pulling fs layer
4d577f7424c0: Pulling fs layer
23222af7238f: Waiting
37ef4781925f: Pulling fs layer
30d67d1af761: Pulling fs layer
59b87d9ed5c1: Waiting
43eaf8c26af4: Pulling fs layer
90d60b432298: Waiting
02f4cc50eabd: Pulling fs layer
93896ee36e56: Pulling fs layer
fadd5d615e0e: Pulling fs layer
85f9459cb30e: Pulling fs layer
d3b3135aa82b: Waiting
eaddca2afacb: Pulling fs layer
f54443d29a2d: Pulling fs layer
94e7b594395d: Waiting
ed6f0f133683: Pulling fs layer
cf15e2c89d00: Waiting
3d1894dc563f: Pulling fs layer
2c0cccf9ec27: Waiting
51ca3f63c909: Pulling fs layer
5d8ea2a8d564: Waiting
b87374db2274: Pulling fs layer
020f04b42275: Waiting
06e22604f387: Waiting
4d577f7424c0: Waiting
37ef4781925f: Waiting
8b0ecc579aad: Waiting
30d67d1af761: Waiting
43eaf8c26af4: Waiting
02f4cc50eabd: Waiting
93896ee36e56: Waiting
fadd5d615e0e: Waiting
85f9459cb30e: Waiting
eaddca2afacb: Waiting
f54443d29a2d: Waiting
ed6f0f133683: Waiting
3d1894dc563f: Waiting
51ca3f63c909: Waiting
b87374db2274: Waiting
7c28a6b187b2: Waiting
7cb9e730d898: Verifying Checksum
7cb9e730d898: Download complete
7c28a6b187b2: Verifying Checksum
7c28a6b187b2: Download complete
af302e5c37e9: Verifying Checksum
af302e5c37e9: Download complete
23222af7238f: Verifying Checksum
23222af7238f: Download complete
ed49ab5c933d: Verifying Checksum
ed49ab5c933d: Download complete
90d60b432298: Verifying Checksum
90d60b432298: Download complete
94e7b594395d: Verifying Checksum
94e7b594395d: Download complete
d3b3135aa82b: Verifying Checksum
d3b3135aa82b: Download complete
cf15e2c89d00: Download complete
2c0cccf9ec27: Verifying Checksum
2c0cccf9ec27: Download complete
5d8ea2a8d564: Verifying Checksum
5d8ea2a8d564: Download complete
020f04b42275: Verifying Checksum
020f04b42275: Download complete
8b0ecc579aad: Verifying Checksum
8b0ecc579aad: Download complete
4d577f7424c0: Download complete
06e22604f387: Verifying Checksum
06e22604f387: Download complete
30d67d1af761: Verifying Checksum
30d67d1af761: Download complete
37ef4781925f: Verifying Checksum
37ef4781925f: Download complete
43eaf8c26af4: Verifying Checksum
43eaf8c26af4: Download complete
02f4cc50eabd: Verifying Checksum
02f4cc50eabd: Download complete
59b87d9ed5c1: Verifying Checksum
59b87d9ed5c1: Download complete
fadd5d615e0e: Download complete
93896ee36e56: Verifying Checksum
93896ee36e56: Download complete
85f9459cb30e: Download complete
eaddca2afacb: Verifying Checksum
f54443d29a2d: Verifying Checksum
3d1894dc563f: Verifying Checksum
51ca3f63c909: Verifying Checksum
b87374db2274: Verifying Checksum
docker: failed to register layer: ApplyLayer exit status 1 stdout:  stderr: unlinkat /tmp/node-compile-cache/v22.13.1-x64-efe9a9df-0: invalid argument.
See 'docker run --help'.
Your Docker installation is not working correctly
See: https://meta.discourse.org/t/docker-error-on-bootstrap/13657/18?u=sam
I followed the advice in the mentioned thread, but running a trivial docker container works without a problem and restarting the docker service also did not change anything.
If I understood it correctly, this basically also only needs a command line rebuild (having enough hw resources).
What did I overlook?
Do you have older OS or why can’t it upgrade docker?
My guess is that your docker is out of date. You might be able to apt install docker-ce, or maybe your OS is out of date and you really want to move to a fresh VM.
this thread has some info about failed upgrade due to docker needing updated
Thanks for the hint everybody, this wasn’t clear to me by looking at the error message. I now updated the OS (indeed it is planned to move to a new system in foreseeable future) and I’m now running the latest docker version:
root@vtdiscourse /var/discourse# docker --version
Docker version 27.5.1, build 9f9e405
The first rebuild, including updating postgreSQL went fine as far as I saw, but the second app rebuild fails again:
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
Digest: sha256:01b8516e5504c0e9bc3707773015ff4407be03a89154194ff3b5b8699291bc26
Status: Image is up to date for discourse/base:2.0.20250129-0720
docker.io/discourse/base:2.0.20250129-0720
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2025-02-07T12:24:01.077847 #1]  INFO -- : Reading from stdin
I, [2025-02-07T12:24:01.088712 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2025-02-07T12:24:01.092158 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2025-02-07T12:24:01.095399 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2025-02-07T12:24:01.098725 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
I, [2025-02-07T12:24:01.101897 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2025-02-07T12:24:01.102188 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/15/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-07T12:24:01.375689 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-07T12:24:01.376033 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-07T12:24:01.376462 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-07T12:24:01.376899 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-07T12:24:01.377215 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-07T12:24:01.377590 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-07T12:24:01.381222 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-07T12:24:01.381793 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-07T12:24:01.382182 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/15/main/pg_hba.conf
I, [2025-02-07T12:24:01.608937 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/15/main/pg_hba.conf
I, [2025-02-07T12:24:01.609239 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/15/main/pg_hba.conf
I, [2025-02-07T12:24:01.609523 #1]  INFO -- : > if [ -f /root/install_postgres ]; then
  /root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
  socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
I, [2025-02-07T12:27:08.142917 #1]  INFO -- : Generating locales (this might take a while)...
  en_US.UTF-8... done
Generation complete.
I, [2025-02-07T12:27:08.143547 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/15/bin/postmaster -D /etc/postgresql/15/main
I, [2025-02-07T12:27:08.149982 #1]  INFO -- : File > /usr/local/bin/create_db  chmod: +x  chown:
I, [2025-02-07T12:27:08.155367 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2025-02-07T12:27:08.158186 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2025-02-07T12:27:08.158385 #1]  INFO -- : > sleep 5
2025-02-07 12:27:08.206 UTC [42] LOG:  starting PostgreSQL 15.10 (Debian 15.10-1.pgdg120+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14) 12.2.0, 64-bit
2025-02-07 12:27:08.206 UTC [42] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2025-02-07 12:27:08.206 UTC [42] LOG:  listening on IPv6 address "::", port 5432
2025-02-07 12:27:08.219 UTC [42] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2025-02-07 12:27:08.237 UTC [53] LOG:  database system was shut down at 2025-02-07 12:20:09 UTC
2025-02-07 12:27:08.248 UTC [42] LOG:  database system is ready to accept connections
I, [2025-02-07T12:27:13.160322 #1]  INFO -- :
I, [2025-02-07T12:27:13.160466 #1]  INFO -- : > /usr/local/bin/create_db
2025-02-07 12:27:13.224 UTC [60] postgres@postgres ERROR:  database "discourse" already exists
2025-02-07 12:27:13.224 UTC [60] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
2025-02-07 12:27:13.284 UTC [63] postgres@discourse ERROR:  role "discourse" already exists
2025-02-07 12:27:13.284 UTC [63] postgres@discourse STATEMENT:  create user discourse;
NOTICE:  extension "hstore" already exists, skipping
NOTICE:  extension "pg_trgm" already exists, skipping
NOTICE:  extension "vector" already exists, skipping
NOTICE:  version "0.8.0" of extension "vector" is already installed
I, [2025-02-07T12:27:13.896203 #1]  INFO -- : GRANT
ALTER SCHEMA
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
UPDATE 0
I, [2025-02-07T12:27:13.896314 #1]  INFO -- : > echo postgres installed!
I, [2025-02-07T12:27:13.898502 #1]  INFO -- : postgres installed!
I, [2025-02-07T12:27:13.901863 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2025-02-07T12:27:13.905158 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2025-02-07T12:27:13.908457 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2025-02-07T12:27:13.908904 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2025-02-07T12:27:14.089263 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2025-02-07T12:27:14.089723 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2025-02-07T12:27:14.092105 #1]  INFO -- :
I, [2025-02-07T12:27:14.092424 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2025-02-07T12:27:14.092948 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2025-02-07T12:27:14.093393 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2025-02-07T12:27:14.093851 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2025-02-07T12:27:14.094231 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2025-02-07T12:27:14.094574 #1]  INFO -- : > echo redis installed
I, [2025-02-07T12:27:14.095877 #1]  INFO -- : redis installed
I, [2025-02-07T12:27:14.096020 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2025-02-07T12:27:14.098793 #1]  INFO -- : logfile ""
I, [2025-02-07T12:27:14.098926 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2025-02-07T12:27:14.100074 #1]  INFO -- : > sleep 10
109:C 07 Feb 2025 12:27:14.111 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
109:C 07 Feb 2025 12:27:14.111 # Redis version=7.0.15, bits=64, commit=00000000, modified=0, pid=109, just started
109:C 07 Feb 2025 12:27:14.111 # Configuration loaded
109:M 07 Feb 2025 12:27:14.111 * monotonic clock: POSIX clock_gettime
109:M 07 Feb 2025 12:27:14.112 * Running mode=standalone, port=6379.
109:M 07 Feb 2025 12:27:14.112 # Server initialized
109:M 07 Feb 2025 12:27:14.112 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
109:M 07 Feb 2025 12:27:14.113 * Loading RDB produced by version 7.0.15
109:M 07 Feb 2025 12:27:14.113 * RDB age 425 seconds
109:M 07 Feb 2025 12:27:14.113 * RDB memory usage when created 2.78 Mb
109:M 07 Feb 2025 12:27:14.120 * Done loading RDB, keys loaded: 1629, keys expired: 1.
109:M 07 Feb 2025 12:27:14.120 * DB loaded from disk: 0.007 seconds
109:M 07 Feb 2025 12:27:14.120 * Ready to accept connections
I, [2025-02-07T12:27:24.101766 #1]  INFO -- :
I, [2025-02-07T12:27:24.101989 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2025-02-07T12:27:24.104708 #1]  INFO -- : thpoff is installed!
I, [2025-02-07T12:27:24.105058 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2025-02-07T12:27:24.198364 #1]  INFO -- :
I, [2025-02-07T12:27:24.198510 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2025-02-07T12:27:24.290864 #1]  INFO -- :
I, [2025-02-07T12:27:24.291001 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2025-02-07T12:27:24.383477 #1]  INFO -- :
I, [2025-02-07T12:27:24.383659 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2025-02-07T12:27:24.385641 #1]  INFO -- :
I, [2025-02-07T12:27:24.387673 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2025-02-07T12:27:24.391186 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2025-02-07T12:27:24.394676 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2025-02-07T12:27:24.397954 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2025-02-07T12:27:24.401316 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2025-02-07T12:27:24.404581 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2025-02-07T12:27:24.404732 #1]  INFO -- : Replacing # postgres with if [ -f /root/install_postgres ]; then
  rm /root/install_postgres
fi
sv start postgres || exit 1
 in /etc/service/unicorn/run
I, [2025-02-07T12:27:24.406272 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2025-02-07T12:27:24.638997 #1]  INFO -- :
I, [2025-02-07T12:27:24.639147 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
 - [deleted]             (none)     -> origin/0-app-events-revolution
 - [deleted]             (none)     -> origin/0-ember-bump-fix-modal
 - [deleted]             (none)     -> origin/0-polls-still
 - [deleted]             (none)     -> origin/0-rename-details
 - [deleted]             (none)     -> origin/0-simpler-placeholder
 - [deleted]             (none)     -> origin/0-store-bump
 - [deleted]             (none)     -> origin/0-tooltip
 - [deleted]             (none)     -> origin/0-user-status
 - [deleted]             (none)     -> origin/add-message-builder-modifier-3
 - [deleted]             (none)     -> origin/add-shift-detect
 - [deleted]             (none)     -> origin/add-shortcuts
 - [deleted]             (none)     -> origin/add-signal-to-notifications-template
 - [deleted]             (none)     -> origin/after-post-outlet
 - [deleted]             (none)     -> origin/again-support-load-more-btn
 - [deleted]             (none)     -> origin/allow-overriding-sidebar-my-posts-icon
 - [deleted]             (none)     -> origin/array-custom-field-order
 - [deleted]             (none)     -> origin/async-category-link
 - [deleted]             (none)     -> origin/bump-eslint-config
 - [deleted]             (none)     -> origin/carsick-patch-1
 - [deleted]             (none)     -> origin/cat-mod-groups
 - [deleted]             (none)     -> origin/category-experts-approved-webhook-event-wip
 - [deleted]             (none)     -> origin/chat-github-onebox
 - [deleted]             (none)     -> origin/chat-uppy-upload
 - [deleted]             (none)     -> origin/conditional-summary-box
 - [deleted]             (none)     -> origin/custom-field-store-cleanup
 - [deleted]             (none)     -> origin/d-object
 - [deleted]             (none)     -> origin/defer-button-action
 - [deleted]             (none)     -> origin/demote-summarize-ai-button
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/uppy-b578ad6dea
 - [deleted]             (none)     -> origin/dev-fail-tests-on-fa6-deprecated-icons-from-svg-sprite-rb
 - [deleted]             (none)     -> origin/dev-faster-tests
 - [deleted]             (none)     -> origin/dev-migrate-user-passwords
 - [deleted]             (none)     -> origin/dev-refactor-username-validation-mixin
 - [deleted]             (none)     -> origin/dev/add-a-reference-column-to-notifications
 - [deleted]             (none)     -> origin/dev/advanced-search-custom-in-special
 - [deleted]             (none)     -> origin/dev/automation-scriptable-add-with-class
 - [deleted]             (none)     -> origin/dev/default-plugin-config-pages
 - [deleted]             (none)     -> origin/dev/drop-ignore-chat_channels_last_message_sent_at
 - [deleted]             (none)     -> origin/dev/port-outlet-wrapper-to-stable
 - [deleted]             (none)     -> origin/dev/refactor-uploads-importer
 - [deleted]             (none)     -> origin/dev/remove-deprecated-respect-plugin-positional-argument
 - [deleted]             (none)     -> origin/dev/sidebar-sections-collapse-expand-transformer-events
 - [deleted]             (none)     -> origin/dev/sidebar-subsections
 - [deleted]             (none)     -> origin/dev/third-party-breadcrumbs
 - [deleted]             (none)     -> origin/dev_add_query_param
 - [deleted]             (none)     -> origin/dev_lazy_load_categories_tests
 - [deleted]             (none)     -> origin/dev_update_category_position
 - [deleted]             (none)     -> origin/docs-publishing-mvp
 - [deleted]             (none)     -> origin/drawer-composer-positioning
 - [deleted]             (none)     -> origin/ember-4
 - [deleted]             (none)     -> origin/expand-allowed-custom-emoji-images-types
 - [deleted]             (none)     -> origin/extra-js-revert
 - [deleted]             (none)     -> origin/feature/add-user-to-topic_tags_changed-event
 - [deleted]             (none)     -> origin/feature/custom-fields-for-existing-users
 - [deleted]             (none)     -> origin/feature/enable-chat-with-dms-only
 - [deleted]             (none)     -> origin/feature/light-dark-mode-switcher
 - [deleted]             (none)     -> origin/feature/paste-upload-on-first-upload-input-templates
 - [deleted]             (none)     -> origin/feature/show-note-bookmark-notif
 - [deleted]             (none)     -> origin/feature/show-status-on-mentions-when-user-havent-used-autocomplete
 - [deleted]             (none)     -> origin/feature_pm_editor
 - [deleted]             (none)     -> origin/feature_track_mentions
 - [deleted]             (none)     -> origin/fix-directory-search-limit
 - [deleted]             (none)     -> origin/fix-display-errors-for-history-modal-when-fetching-revisions
 - [deleted]             (none)     -> origin/fix-password-reset-security-key
 - [deleted]             (none)     -> origin/fix-safari-below-18-detection
 - [deleted]             (none)     -> origin/fix-search-context-delete-key
 - [deleted]             (none)     -> origin/fix-unread-notifications-take-2
 - [deleted]             (none)     -> origin/fix/tag-rename-404
 - [deleted]             (none)     -> origin/full-page
 - [deleted]             (none)     -> origin/glimmer-header-dnd-live
 - [deleted]             (none)     -> origin/group_and_tag_group_permission_change_notification
 - [deleted]             (none)     -> origin/handle-non-ascii-charc
 - [deleted]             (none)     -> origin/hijacks
 - [deleted]             (none)     -> origin/history-store-methods
 - [deleted]             (none)     -> origin/i18n-helper-import
 - [deleted]             (none)     -> origin/image-assets
 - [deleted]             (none)     -> origin/implicit-injections-deprecations
 - [deleted]             (none)     -> origin/improve-claimed-reviewables-transactions
 - [deleted]             (none)     -> origin/issue/do-not-enforce-2fa-on-social-logins
 - [deleted]             (none)     -> origin/issue/fix-user-field-enum-migrate
 - [deleted]             (none)     -> origin/issue/fixup-upload-ref-backfill-migration-dates
 - [deleted]             (none)     -> origin/list-wrapper
 - [deleted]             (none)     -> origin/live-cache
 - [deleted]             (none)     -> origin/lock-step
 - [deleted]             (none)     -> origin/loic-upgrade-miniracer
 - [deleted]             (none)     -> origin/more-topics-active
 - [deleted]             (none)     -> origin/nginx-conf
 - [deleted]             (none)     -> origin/oklab
 - [deleted]             (none)     -> origin/plugin-outlet-no-subdir
 - [deleted]             (none)     -> origin/post-widget-outlet
 - [deleted]             (none)     -> origin/powered-by-reactivity
 - [deleted]             (none)     -> origin/promote-migration-tweak
 - [deleted]             (none)     -> origin/prune-old-transpilers
 - [deleted]             (none)     -> origin/remap-assume-yes-option
 - [deleted]             (none)     -> origin/remove-bootbox
 - [deleted]             (none)     -> origin/remove-muted-from-hot-and-top-topic-lists
 - [deleted]             (none)     -> origin/remove-x-count
 - [deleted]             (none)     -> origin/render-glimmer-granular
 - [deleted]             (none)     -> origin/revert-28587-revert-28321-dev/remove-create_post_for_category_and_tag_changes-setting
 - [deleted]             (none)     -> origin/revert-location-change
 - [deleted]             (none)     -> origin/revert-thread-title-experiment
 - [deleted]             (none)     -> origin/see_if_yarn_cache_is_working
 - [deleted]             (none)     -> origin/shared-draft-category
 - [deleted]             (none)     -> origin/skip-back-button-animation
 - [deleted]             (none)     -> origin/tag-span
 - [deleted]             (none)     -> origin/testing_debian_12
 - [deleted]             (none)     -> origin/tobiaseigen-patch-4
 - [deleted]             (none)     -> origin/topic-count-fix
 - [deleted]             (none)     -> origin/topic-list-item-style
 - [deleted]             (none)     -> origin/translations-from-crowdin-main
 - [deleted]             (none)     -> origin/translations-from-crowdin-stable
 - [deleted]             (none)     -> origin/update-gems-stable
 - [deleted]             (none)     -> origin/ux/admin-site-setting-inner-sidebar-experiment
 - [deleted]             (none)     -> origin/whats-new-notify-plugins
   c64b5d6d7..6b6b31a97  main                    -> origin/main
 * [new branch]          0-a-pnpm-lock           -> origin/0-a-pnpm-lock
 + 3c0b2f75f...0d2238318 allow-posts-link-in-sidebar -> origin/allow-posts-link-in-sidebar  (forced update)
 * [new branch]          async-data              -> origin/async-data
 * [new branch]          automation-autoload     -> origin/automation-autoload
 + c35147e8c...a4758855f composer-disable-submit -> origin/composer-disable-submit  (forced update)
 * [new branch]          d-menu-composer-flag    -> origin/d-menu-composer-flag
 * [new branch]          dependabot/bundler/msgpack-1.8.0 -> origin/dependabot/bundler/msgpack-1.8.0
 * [new branch]          dependabot/bundler/net-smtp-0.5.1 -> origin/dependabot/bundler/net-smtp-0.5.1
 * [new branch]          dependabot/bundler/parser-3.3.7.1 -> origin/dependabot/bundler/parser-3.3.7.1
 * [new branch]          dependabot/bundler/rdoc-6.12.0 -> origin/dependabot/bundler/rdoc-6.12.0
 * [new branch]          dependabot/bundler/rspec-core-3.13.3 -> origin/dependabot/bundler/rspec-core-3.13.3
 * [new branch]          dependabot/bundler/rspec-rails-7.1.1 -> origin/dependabot/bundler/rspec-rails-7.1.1
 * [new branch]          dependabot/bundler/rubocop-1.71.2 -> origin/dependabot/bundler/rubocop-1.71.2
 * [new branch]          dependabot/bundler/webmock-3.25.0 -> origin/dependabot/bundler/webmock-3.25.0
 * [new branch]          dependabot/npm_and_yarn/discourse/lint-configs-2.4.0 -> origin/dependabot/npm_and_yarn/discourse/lint-configs-2.4.0
 * [new branch]          dependabot/npm_and_yarn/ember-cli-6.2.0 -> origin/dependabot/npm_and_yarn/ember-cli-6.2.0
 * [new branch]          dependabot/npm_and_yarn/prosemirror-view-1.37.2 -> origin/dependabot/npm_and_yarn/prosemirror-view-1.37.2
 * [new branch]          dependabot/npm_and_yarn/puppeteer-core-24.2.0 -> origin/dependabot/npm_and_yarn/puppeteer-core-24.2.0
 * [new branch]          dependabot/npm_and_yarn/swc/core-1.10.14 -> origin/dependabot/npm_and_yarn/swc/core-1.10.14
 * [new branch]          dependabot/npm_and_yarn/terser-5.38.1 -> origin/dependabot/npm_and_yarn/terser-5.38.1
 * [new branch]          dependabot/npm_and_yarn/uppy-b82cdcd59c -> origin/dependabot/npm_and_yarn/uppy-b82cdcd59c
 * [new branch]          dev-better-backtrace-for-deprecated-icon-names-from-plugins-in-tests -> origin/dev-better-backtrace-for-deprecated-icon-names-from-plugins-in-tests
 + 72ff8f1eb...699aa3755 dev-refactor-username-validation-mixin-to-helper -> origin/dev-refactor-username-validation-mixin-to-helper  (forced update)
 * [new branch]          dev/async-content-component -> origin/dev/async-content-component
 + ec68ffb95...2124c96a9 dev/color-palette-editor -> origin/dev/color-palette-editor  (forced update)
 * [new branch]          dev/ember-async-data-demo -> origin/dev/ember-async-data-demo
 * [new branch]          dev/purge-widget-post-menu -> origin/dev/purge-widget-post-menu
 * [new branch]          dev/user-field-components-transformer -> origin/dev/user-field-components-transformer
 * [new branch]          feature_pm_codeblock    -> origin/feature_pm_codeblock
 * [new branch]          feature_pm_emoji        -> origin/feature_pm_emoji
 * [new branch]          feature_pm_hashtag      -> origin/feature_pm_hashtag
 * [new branch]          feature_pm_html_block   -> origin/feature_pm_html_block
 * [new branch]          feature_pm_html_inline  -> origin/feature_pm_html_inline
 * [new branch]          feature_pm_image        -> origin/feature_pm_image
 * [new branch]          feature_pm_link         -> origin/feature_pm_link
 * [new branch]          feature_pm_mention      -> origin/feature_pm_mention
 * [new branch]          feature_pm_quote        -> origin/feature_pm_quote
 * [new branch]          feature_pm_strikethrough -> origin/feature_pm_strikethrough
 * [new branch]          feature_pm_table        -> origin/feature_pm_table
 * [new branch]          feature_pm_typographer  -> origin/feature_pm_typographer
 * [new branch]          feature_pm_underline    -> origin/feature_pm_underline
 * [new branch]          fix/secure-upload-rake-dedup-no-post -> origin/fix/secure-upload-rake-dedup-no-post
 + 0f2f74d08...18fbfb9cb mt/idb                  -> origin/mt/idb  (forced update)
 * [new branch]          mt/update-default-config -> origin/mt/update-default-config
 * [new branch]          omit-date-in-user-stream-small-actions -> origin/omit-date-in-user-stream-small-actions
 * [new branch]          pento/dev-upgrade-pnpm-10 -> origin/pento/dev-upgrade-pnpm-10
 * [new branch]          quick-smoke-test        -> origin/quick-smoke-test
 + de3691471...e5890e554 renato/pm               -> origin/renato/pm  (forced update)
   5d4c2a89e..22f2a554e  stable                  -> origin/stable
   c64b5d6d7..6b6b31a97  tests-passed            -> origin/tests-passed
 * [new branch]          tobiaseigen-patch-3     -> origin/tobiaseigen-patch-3
 * [new branch]          tobiaseigen-patch-3-1   -> origin/tobiaseigen-patch-3-1
   415cccafb..c43caf483  user-fields-plugin-outlets-update -> origin/user-fields-plugin-outlets-update
 * [new branch]          user-stream-item-alignment-fix -> origin/user-stream-item-alignment-fix
   10566d84b..c540132fe  ux/combined-themes-components-sidebar-links -> origin/ux/combined-themes-components-sidebar-links
 t [tag update]          beta                    -> beta
 t [tag update]          latest-release          -> latest-release
 * [new tag]             v3.3.4                  -> v3.3.4
 * [new tag]             v3.4.0                  -> v3.4.0
 * [new tag]             v3.4.0.beta4            -> v3.4.0.beta4
I, [2025-02-07T12:27:26.047219 #1]  INFO -- :
I, [2025-02-07T12:27:26.047365 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2025-02-07T12:27:32.242164 #1]  INFO -- : branch 'tests-passed' set up to track 'origin/tests-passed'.
I, [2025-02-07T12:27:32.242306 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2025-02-07T12:27:32.253644 #1]  INFO -- :
I, [2025-02-07T12:27:32.253780 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2025-02-07T12:27:32.256418 #1]  INFO -- :
I, [2025-02-07T12:27:32.256500 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2025-02-07T12:27:32.258899 #1]  INFO -- :
I, [2025-02-07T12:27:32.258965 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2025-02-07T12:27:32.261423 #1]  INFO -- :
I, [2025-02-07T12:27:32.261536 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2025-02-07T12:27:32.263798 #1]  INFO -- :
I, [2025-02-07T12:27:32.263864 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2025-02-07T12:27:32.266054 #1]  INFO -- :
I, [2025-02-07T12:27:32.266120 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2025-02-07T12:27:32.268279 #1]  INFO -- :
I, [2025-02-07T12:27:32.268346 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2025-02-07T12:27:32.271876 #1]  INFO -- :
I, [2025-02-07T12:27:32.271943 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2025-02-07T12:27:32.275766 #1]  INFO -- :
I, [2025-02-07T12:27:32.275833 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2025-02-07T12:27:32.279336 #1]  INFO -- :
I, [2025-02-07T12:27:32.279449 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2025-02-07T12:27:32.282869 #1]  INFO -- :
I, [2025-02-07T12:27:32.282985 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2025-02-07T12:27:32.286437 #1]  INFO -- :
I, [2025-02-07T12:27:32.286552 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2025-02-07T12:27:32.289936 #1]  INFO -- :
I, [2025-02-07T12:27:32.290051 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2025-02-07T12:27:32.295538 #1]  INFO -- :
I, [2025-02-07T12:27:32.295660 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2025-02-07T12:27:32.297217 #1]  INFO -- :
I, [2025-02-07T12:27:32.297447 #1]  INFO -- : Replacing # redis with if [ ! -d /shared/redis_data ]; then
fi
sv start redis || exit 1 in /etc/service/unicorn/run
I, [2025-02-07T12:27:32.297853 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2025-02-07T12:27:33.282135 #1]  INFO -- :
I, [2025-02-07T12:27:33.282282 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/communiteq/discourse-private-topics.git
Cloning into 'discourse-private-topics'...
I, [2025-02-07T12:27:33.838661 #1]  INFO -- :
I, [2025-02-07T12:27:33.838987 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2025-02-07T12:27:33.841660 #1]  INFO -- :
I, [2025-02-07T12:27:33.841772 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2025-02-07T12:27:33.843420 #1]  INFO -- :
I, [2025-02-07T12:27:33.843484 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2025-02-07T12:27:33.845230 #1]  INFO -- :
I, [2025-02-07T12:27:33.845418 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2025-02-07T12:27:34.158786 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2025-02-07T12:27:34.159111 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2025-02-07T12:27:34.159474 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2025-02-07T12:27:34.159788 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2025-02-07T12:27:34.160072 #1]  INFO -- : > echo "done configuring web"
I, [2025-02-07T12:27:34.161854 #1]  INFO -- : done configuring web
I, [2025-02-07T12:27:34.162105 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2025-02-07T12:27:34.468978 #1]  INFO -- :
I, [2025-02-07T12:27:34.469096 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2025-02-07T12:27:36.908120 #1]  INFO -- :
I, [2025-02-07T12:27:36.908416 #1]  INFO -- : > cd /var/www/discourse && if [ -f yarn.lock ]; then
  if [ -d node_modules/.pnpm ]; then
    echo "This version of Discourse uses yarn, but pnpm node_modules are preset. Cleaning up..."
    find ./node_modules ./app/assets/javascripts/*/node_modules -mindepth 1 -maxdepth 1 -exec rm -rf {} +
  fi
  su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
else
  su discourse -c 'CI=1 pnpm install --frozen-lockfile && pnpm prune'
fi
I, [2025-02-07T12:27:38.403844 #1]  INFO -- : Scope: all 17 workspace projects
Lockfile is up to date, resolution step is skipped
 EINVAL  EINVAL: invalid argument, rmdir '/var/www/discourse/app/assets/javascripts/dialog-holder/node_modules/.bin'
I, [2025-02-07T12:27:38.404328 #1]  INFO -- : Terminating async processes
I, [2025-02-07T12:27:38.404370 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/15/bin/postmaster -D /etc/postgresql/15/main pid: 42
I, [2025-02-07T12:27:38.404438 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 109
2025-02-07 12:27:38.404 UTC [42] LOG:  received fast shutdown request
109:signal-handler (1738931258) Received SIGTERM scheduling shutdown...
2025-02-07 12:27:38.434 UTC [42] LOG:  aborting any active transactions
2025-02-07 12:27:38.436 UTC [42] LOG:  background worker "logical replication launcher" (PID 56) exited with exit code 1
2025-02-07 12:27:38.436 UTC [51] LOG:  shutting down
2025-02-07 12:27:38.443 UTC [51] LOG:  checkpoint starting: shutdown immediate
109:M 07 Feb 2025 12:27:38.499 # User requested shutdown...
109:M 07 Feb 2025 12:27:38.499 * Saving the final RDB snapshot before exiting.
2025-02-07 12:27:38.507 UTC [51] LOG:  checkpoint complete: wrote 4 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.002 s, sync=0.027 s, total=0.071 s; sync files=3, longest=0.010 s, average=0.009 s; distance=5 kB, estimate=5 kB
2025-02-07 12:27:38.514 UTC [42] LOG:  database system is shut down
109:M 07 Feb 2025 12:27:38.541 * DB saved on disk
109:M 07 Feb 2025 12:27:38.541 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && if [ -f yarn.lock ]; then
  fi
else
fi failed with return #<Process::Status: pid 290 exit 234>
exec failed with the params {"cd"=>"$home", "hook"=>"yarn", "cmd"=>["if [ -f yarn.lock ]; then\n  if [ -d node_modules/.pnpm ]; then\n    echo \"This version of Discourse uses yarn, but pnpm node_modules are preset. Cleaning up...\"\n    find ./node_modules ./app/assets/javascripts/*/node_modules -mindepth 1 -maxdepth 1 -exec rm -rf {} +\n  fi\n  su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'\nelse\n  su discourse -c 'CI=1 pnpm install --frozen-lockfile && pnpm prune'\nfi"]}
bootstrap failed with exit code 234
ca4136b0e8118d0ec935d9c725cd78463f542b74c8734ca79d278dc94ec76b56
I still fail to see what went wrong. Is there another log file I should consult? Thx again for any hints!
As the problem persists and I’m clueless, I’m wondering if anyone can give me a hint how to debug the issue. Thanks!
Have you tried rebuilding again?
yes, yesterday just before posting again, I tried again and failed again.
The solution in my case was to move to newer hardware with a newer virtual environment. See:
