Updated Custom Header Icon: Post Data via URL
In a Dev category discussion titled “Updated Custom Header Icon: Post Data via URL,” littleviolette seeks help migrating from the deprecated api.decorateWidget to the new headerIcons API to silently post the current user’s username to a URL via a header icon. Arkshine clarifies the goal — a clickable icon that redirects to a URL with the username as a query parameter — and provides a working example using apiInitializer and a Glimmer template with DButton. The example uses encodeURIComponent to safely include the username in the URL and places the icon before the search icon. littleviolette tries pasting the code into <head> but sees no icon, prompting Arkshine to explain that the Glimmer <template> syntax requires a theme component built via the Discourse CLI, not the Admin UI. Arkshine advises creating a .gjs file in /javascripts/discourse/api-initializers/ and installing the component via GitHub or ZIP upload. The thread ends with an invitation for further questions.
Discourse has recently deprecated api.decorateWidget, which I used to insert custom header icons and post the current user’s username via a URL.
I was wondering how I can post the user’s current username via HTTP with the new headerIcons API. I couldn’t find any documentation or examples on how to implement this. I couldn’t find a way to do it via the Customer Header Link plugin either.
Appreciate your help! Below is my current code using the decorateWidget API to post the username:
<script type="text/discourse-plugin" version="0.12">
    const { iconNode } = require("discourse-common/lib/icon-library");
    let icon = iconNode('calculator');
    var currentUser = api.getCurrentUser();
    var username = currentUser.username;
    api.decorateWidget('header-icons:before', helper => {
        const showExtraInfo = helper.attrs.minimized;
            if(!showExtraInfo) {
                return helper.h('li#calculator', [
                    helper.h('form#header-calculator.icon', {
                        action:'https://example.com/',
                        method:'post'
                        helper.h('button', {name:'u', value: username},[
                            iconNode('calculator'),
</script>
Hey,
I will help you, but can you explain what you’re trying to do before that?
Is it to display a menu with a form inside?
Like for example:
Or is it just a button with the username as label, and it redirects to some URL?
It’s to click the header icon >> post the user’s username to a specified URL.
No form is actually displayed. Only the header icon is displayed. The post action is performed behind the scene. Sorry for the confusion. Let me remove “form” from the title of my post.
Okay, so a redirection to an external URL that contains the username.
Here is a basic example on how you can do, using the new API:
import DButton from "discourse/components/d-button";
export default apiInitializer("1.8.0", (api) => {
  const currentUser = api.getCurrentUser();
  if (!currentUser) {
    return;
  const url =
    "https://example.com/?u=" + encodeURIComponent(currentUser.username);
  const iconComponent = <template>
    <li class="calculator">
      <DButton
        @href={{url}}
        @icon="calculator"
        class="icon btn-flat"
        title="Calculator"
        target="_blank"
    </li>
  </template>;
  api.headerIcons.add("calculator", iconComponent, { before: "search" });
  • calculator is a unique name
  • iconComponent refers to an inline glimmer <template> as you see here, but it can also refer to a glimmer class component you create in the components directory.
  • You can choose where to place your icon by using before or after followed by the header icon’s unique name.
NVIDIA_Share_rvsjetCtUy
Feel free to adjust!
Note:
Let me know if you need further help!
Hi @Arkshine ,
Thank you so much for the detailed write-up. I tried injecting the code in <head> but is not seeing the icon show up. What did I do wrong?
<script type="text/discourse-plugin">
      if (!currentUser) {
        return;
      const url =
      console.log("url: " + url)
          <DButton
            @href={{url}}
            @icon="calculator"
            title="Calculator"
            target="_blank"
        </li>
      </template>;
</script>
@littleviolette Hi, it can’t be run in the Admin UI here.
Using the Theme CLI, you can easily create a theme component on your computer.
Then, you edit the file with a text editor of your choice (like vscode) and add the code in the initializer. You make a file in /javascripts/discourse/api-initializers/my-header-icon.gjs and you paste the code in it. You can also change the default values in about.json.
The next step to install the component on your production forum:
  • you can either put the component on Github and in the Admin UI, use the repository link to install;
  • or you zip the directory on your computer, and in the Admin UI, you install it from the device.
Give it a shot and let me know if you have any issues!
