axfelix
(Alex Garnett)
3 במאי, 2022, 3:34pm
1
Had an automatic rebuild fail, looks like variations on this issue:
2022-05-03 15:30:54.370 UTC [1262] discourse@discourse LOG: duration: 1707.909 ms statement: INSERT INTO post_hotlinked_media (post_id, url, status, upload_id, created_at, updated_at)
SELECT
post_id,
obj.key AS url,
'downloaded',
obj.value::bigint AS upload_id,
pcf.created_at,
pcf.updated_at
FROM post_custom_fields pcf
JOIN json_each_text(pcf.value::json) obj ON true
JOIN uploads ON obj.value::bigint = uploads.id
WHERE name='downloaded_images'
ERROR: duplicate key value violates unique constraint "index_post_hotlinked_media_on_post_id_and_url_md5"
Had rebuilt less than a month ago with no errors so whatever introduced this seems to have been recent.
4 לייקים
axfelix
(Alex Garnett)
3 במאי, 2022, 4:09pm
3
seems to be something to do with this recent commit?
# frozen_string_literal: true
class CreatePostHotlinkedMedia < ActiveRecord::Migration[6.1]
def change
reversible do |dir|
dir.up do
execute <<~SQL
CREATE TYPE hotlinked_media_status AS ENUM('downloaded', 'too_large', 'download_failed', 'upload_create_failed')
SQL
dir.down do
execute <<~SQL
DROP TYPE hotlinked_media_status
SQL
create_table :post_hotlinked_media do |t|
t.bigint :post_id, null: false
t.string :url, null: false
This file has been truncated. show original
@david
2 לייקים
david
(David Taylor)
3 במאי, 2022, 4:15pm
4
Yep that’s it. I have a fix in the pipeline, should be merged in the next few minutes. Thanks for reporting @axfelix
main ← hotlinked-conflict
merged 04:17PM - 03 May 22 UTC
In the old custom_field-based system, it was possible for a url to be both 'down… loaded' and 'broken'. The new table enforces uniqueness, so we need to drop invalid data.
9 לייקים
axfelix
(Alex Garnett)
3 במאי, 2022, 4:39pm
5
Thanks, that was fast!
Do I need to do anything special to pull this down? I’m still getting Caused by: ActiveRecord::RecordNotUnique: PG::UniqueViolation: ERROR: duplicate key value violates unique constraint "index_post_hotlinked_media_on_post_id_and_url_md5" when running a launcher rebuild, even after doing a Docker prune.
david
(David Taylor)
3 במאי, 2022, 4:48pm
6
The fix just hit tests-passed a few seconds ago. If you rebuild now, it should work much better. Let us know how it goes.
5 לייקים
david
(David Taylor)
3 במאי, 2022, 6:07pm
7
We found one more place which can cause this error. So if the first fix didn’t help, this one should
committed 05:51PM - 03 May 22 UTC
custom_field data on some sites has duplicate values for a given url key in the … JSON value. This is invalid, so we should drop the extra data.
(now live in tests-passed)
4 לייקים
pfaffman
(Jay Pfaffman)
3 במאי, 2022, 7:31pm
8
On my development instance it does successfully migrate the database, but if I restore a backup from 2022-04-27-153103-v20220407195246.tar.gz it fails:
[361/9020]
Migrating the database... EXCEPTION: /home/pfaffman/src/discourse-repos/discourse/lib/discourse.rb:126:in `exec': Failed to migrat
e database.
Ignoring /home/pfaffman/src/discourse-repos/discourse/db/schema_cache.yml because it has expired. The cu
rrent schema version is 20220407195246, but the one in the schema cache file is 20220428094027.
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
followed by some more of that with some of these:
ActiveRecord::StatementInvalid: PG::DuplicateObject: ERROR: type "hotlinked_media_status" already exist
לייק 1
axfelix
(Alex Garnett)
3 במאי, 2022, 9:22pm
9
Just chiming in to say that the first fix worked for us after it passed tests!
2 לייקים
david
(David Taylor)
3 במאי, 2022, 9:30pm
10
Alex Garnett:
Great, thanks for confirming!
I opened a PR with a fix for that one:
main ← fix-restore-enums
merged 10:40PM - 03 May 22 UTC
c1db9687 introduced an postgres enum type. Our database restore logic did not ha… ndle custom types correctly, and would therefore raise a 'type already exists' error when restoring any backup.
This commit adds restore handling for enums, mirroring the similar logic for tables and views.
(This code is not tested by rspec, but it is tested by a regular internal job at CDCK, which correctly picked up on this issue)
4 לייקים
pfaffman
(Jay Pfaffman)
4 במאי, 2022, 2:05pm
11
Finished!
[SUCCESS]
Restore done.
Thanks!
2 לייקים
