Hallo,
wir versuchen, eine sehr alte Discourse-Installation (v1.2.4) auf die neueste Version 2.3.1 zu aktualisieren. Unsere ersten Test-Migrationen mit v2.2.0 verliefen überraschend gut, und der Migrationsprozess wurde ohne Probleme abgeschlossen.
Nun versuchen wir jedoch, den Prozess in den letzten Stufen gegen v2.3.1 auszuführen, und erhalten folgenden Fehler:
PG::UniqueViolation: ERROR: duplicate key value violates unique constraint "idx_unique_rows"
DETAIL: Key (action_type, user_id, target_topic_id, target_post_id, acting_user_id)=(15, 1140990, 9346002, 9431164, 419835) already exists.
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.0.2/lib/patches/db/pg.rb:110:in `async_exec'
(eval):24:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mini_sql-0.2.2/lib/mini_sql/postgres/connection.rb:118:in `run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mini_sql-0.2.2/lib/mini_sql/postgres/connection.rb:90:in `exec'
/var/www/discourse/plugins/discourse-solved/plugin.rb:64:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:328:in `block in notify_after_initialize'
/var/www/discourse/lib/plugin/instance.rb:326:in `each'
/var/www/discourse/lib/plugin/instance.rb:326:in `notify_after_initialize'
/var/www/discourse/config/application.rb:292:in `each'
/var/www/discourse/config/application.rb:292:in `block in <class:Application>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/lazy_load_hooks.rb:69:in `block in execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/lazy_load_hooks.rb:62:in `with_execution_control'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/lazy_load_hooks.rb:67:in `execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/lazy_load_hooks.rb:52:in `block in run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/lazy_load_hooks.rb:51:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/lazy_load_hooks.rb:51:in `run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/application/finisher.rb:75:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/initializable.rb:61:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/application.rb:361:in `initialize!'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/config/environment.rb:7:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/dependencies.rb:291:in `require'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/dependencies.rb:291:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/dependencies.rb:257:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/application.rb:337:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/application.rb:520:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-12.3.2/exe/rake:27:in `<top (required)>'
/var/www/discourse/bin/bundle:5:in `load'
/var/www/discourse/bin/bundle:5:in `<main>'
Tasks: TOP => db:migrate => db:load_config => environment
Dies scheint durch „20120816050526_add_unique_constraint_to_user_actions.rb" verursacht zu werden. Wenn ich mir die Tabelle „schema_migrations" in der Datenbank anschaue, scheint diese Migration bereits angewendet worden zu sein. Diese Migration wurde offenbar bereits 2012 hinzugefügt.
Haben Sie eine Idee, warum „bundle exec rake db:migrate" bereits angewendete Migrationen erneut ausführt, oder was wir falsch machen?
Ich weiß, dass die Quellversion ziemlich alt ist, aber wie bereits erwähnt, haben wir bereits erfolgreiche Ergebnisse erzielt.
Mit freundlichen Grüßen
