uwe_keim
(Uwe Keim)
4 Agosto, 2015 14:56
1
Tried to do an upgrade through the web UI, it failed.
I then did the usual
cd /var/discourse
git pull
./launcher rebuild app
but it also failed (discourse-upgrade-failed.txt ):
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
I’ve found this error, scrolling up.
NoMethodError: undefined method `attributes’ for TopicListItemSerializer:Class
Now my website is down and I’m really clueless.
My question:
How to approach this and bring my website back online again?
jspautsch
(Jonathan Pautsch)
4 Agosto, 2015 14:57
I’m curious, do you have the discourse-tagging plugin installed? Can you scroll up in the output and see if you spot any other errors?
Like this one:
uwe_keim
(Uwe Keim)
3
Yes, the discourse-tagging plugin is installed.
I’ve attached the whole output and found:
jspautsch
(Jonathan Pautsch)
4 Agosto, 2015 14:59
4
Yeah you’re getting the same error I am. The latest changes to the tagging plugin seem to have broken my instance. I have temporarily disabled the tagging plugin and was able to build successfully.
uwe_keim
(Uwe Keim)
4 Agosto, 2015 15:01
5
eviltrout
(Robin Ward)
4 Agosto, 2015 15:21
6
I’ve fixed this issue in the tagging plugin and it’s now compatible with our stable/beta branches again without failing:
https://github.com/discourse/discourse-tagging/commit/04513d372c386a741aa63c3bca7db90784dabb40
@sam we should discuss why I think the extend APIs I baked in there are a good idea – it would have prevented this issue for example.
uwe_keim
(Uwe Keim)
4 Agosto, 2015 17:35
7
Works again, thank you for your fast help.
