Upgrading Bug after latest commits
A bug occurred when upgrading Discourse using the /admin/upgrade path after the latest commits. The error is related to invalid locale data in the discourse-tagging plugin’s server.de.yml file. Falco identified the problematic commit and linked to the fix, which is available in a pull request.
upgrading via /admin/upgrade
Upgrading Discourse tagging plugging plugin
got this bug
Purging temp files
rake aborted!
I18n::InvalidLocaleData: can not load translations from /var/www/discourse/plugins/discourse-tagging/config/locales/server.de.yml: #
  (in /var/www/discourse/app/assets/javascripts/locales/de.js.erb)
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/i18n-0.7.0/lib/i18n/backend/base.rb:184:in `rescue in load_yml'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/i18n-0.7.0/lib/i18n/backend/base.rb:181:in `load_yml'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/i18n-0.7.0/lib/i18n/backend/base.rb:165:in `load_file'
/var/www/discourse/lib/i18n/backend/discourse_i18n.rb:25:in `block in load_translations'
/var/www/discourse/lib/i18n/backend/discourse_i18n.rb:25:in `each'
/var/www/discourse/lib/i18n/backend/discourse_i18n.rb:25:in `load_translations'
/var/www/discourse/lib/freedom_patches/translate_accelerator.rb:44:in `block in load_locale'
/var/www/discourse/lib/freedom_patches/translate_accelerator.rb:35:in `synchronize'
/var/www/discourse/lib/freedom_patches/translate_accelerator.rb:35:in `load_locale'
/var/www/discourse/lib/freedom_patches/translate_accelerator.rb:132:in `translate'
/var/www/discourse/lib/js_locale_helper.rb:121:in `moment_format_function'
/var/www/discourse/lib/js_locale_helper.rb:114:in `moment_formats'
/var/www/discourse/lib/js_locale_helper.rb:105:in `output_locale'
/var/www/discourse/app/assets/javascripts/locales/de.js.erb:3:in `block in singleton class'
/var/www/discourse/app/assets/javascripts/locales/de.js.erb:-5:in `instance_eval'
/var/www/discourse/app/assets/javascripts/locales/de.js.erb:-5:in `singleton class'
/var/www/discourse/app/assets/javascripts/locales/de.js.erb:-7:in `__tilt_47380357070460'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/tilt-1.4.1/lib/tilt/template.rb:170:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/tilt-1.4.1/lib/tilt/template.rb:170:in `evaluate'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/tilt-1.4.1/lib/tilt/template.rb:103:in `render'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/context.rb:197:in `block in evaluate'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/context.rb:194:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/context.rb:194:in `evaluate'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/processed_asset.rb:12:in `initialize'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/base.rb:374:in `new'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/base.rb:374:in `block in build_asset'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/base.rb:395:in `circular_call_protection'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/base.rb:373:in `build_asset'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/index.rb:94:in `block in build_asset'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/caching.rb:58:in `cache_asset'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/index.rb:93:in `build_asset'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/base.rb:287:in `find_asset'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/index.rb:61:in `find_asset'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/bundled_asset.rb:16:in `initialize'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/base.rb:377:in `new'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/base.rb:377:in `build_asset'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/manifest.rb:211:in `block in find_asset'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/manifest.rb:257:in `benchmark'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/manifest.rb:210:in `find_asset'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/manifest.rb:119:in `block in compile'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/manifest.rb:118:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/sprockets/manifest.rb:118:in `compile'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-rails-2.0.1/lib/sprockets/rails/task.rb:60:in `block (3 levels) in define'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-2.11.0/lib/rake/sprocketstask.rb:146:in `with_logger'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/sprockets-rails-2.0.1/lib/sprockets/rails/task.rb:59:in `block (2 levels) in define'
Tasks: TOP => assets:precompile
This commit made the server.DE invalid =(
Fixed via:
