Afbeeldingen uploaden vanuit een Github .md bestand met de Discourse API
Hi all,
I use a Node.js workflow to connect Github repository and Discourse through Discourse API.
Every time someone pushes .md file in a repository automatically Discourse topic is created using POST request https://{defaultHost}/posts.json or if the topic already exits - I just update it with PUT request https://{defaultHost}/posts/{id}.json.
I have a problem with the images - there is couple of ways to include image in Github .md file. The following are working fine and the images are uploaded to Discourse:
but the following two are not working:
Is there a way to ensure that all the images from the .md file will be uploaded to Discourse?
If your script is pushing the raw md from github to discourse then you’ll need to have your script find those relative links and add the github domain.
