How to encode URLs for LinkedIn share buttons in Discourse
In a Discourse-hosted community, bruno_at_dq sought to add a LinkedIn share button to badges using a Plugin Outlet, but encountered an issue where the URL’s username=<username> parameter was being ignored due to lack of encoding. The problem stemmed from the unencoded = in the query string when passed to LinkedIn’s certUrl parameter. To resolve this, bruno_at_dq implemented a solution using the Discourse Theme CLI: creating a component theme with a JavaScript file that uses encodeURIComponent to properly encode @outletArgs.url, and a corresponding Handlebars template for rendering the button. The JavaScript file included @service siteSettings, which merefield questioned as unnecessary — a point bruno_at_dq acknowledged and confirmed was redundant. The solution effectively ensures the full badge URL, including dynamic username parameters, is safely encoded for LinkedIn’s profile add endpoint.
I’m trying to add a LinkedIn share button to badges in a Discourse-hosted community I’m an admin in.
To this end, I’m trying to use this Plugin Outlet. I included the following code in the head section of a theme.
<script type='text/x-handlebars' data-template-name='/connectors/badge-contents-top/linkedin-button'>
  <a href="https://www.linkedin.com/profile/add?certUrl=https://community.my_community.io{{@outletArgs.url}}" class="linkedin-share-button">
    <img src="https://download.linkedin.com/desktop/add2profile/buttons/en_US.png " alt="LinkedIn Add to Profile button">
  </a>
</script>
Please note href attribute: https://www.linkedin.com/profile/add?certUrl=https://community.my_community.io/{{@outletArgs.url}}.
The @outletArgs.url value looks something like https://community.my_community.io/badges/<badge_id>/<badge_name>?username=<username>. I want to focus on the username=<username> part.
The URL is not encoded, the equal sign is being passed literally, so when the browser processes https://www.linkedin.com/profile/add?certUrl=https://community.my_community.io/https://community.my_community.io/badges/<badge_id>/<badge_name>?username=<username>, it ignores =<username>.
How do I encode the URL here?
I handled this by using Discourse Theme CLI in the following way:
  • Created a new theme and made it a component (ran discourse_theme new and followed the prompts).
  • In javascripts/discourse/connectors/badge-contents-top created a JavaScript file with content not far from. . .
    import Component from "@glimmer/component";
    import { inject as service } from "@ember/service";
    export default class LinkedinButton extends Component {
      @service siteSettings;
      get encodedUrl() {
        return encodeURIComponent(this.args.outletArgs.url);
  • In the same directory as above, created a Handlebars file that roughly contains the inner HTML from the script tag in the question.
    • I gave this and the previous file the same name, other than their termination, that is, for what it’s worth.
I don’t see an application of this? Is it redundant?
Yes! Thank you for catching that.
