Usa uno script di importazione che richiede MySQL
With the latest update ver 2.0.0 beta10 I’m now getting more errors with the bbpress import script (still can’t figure out why images are not being pulled over, but instead referring to their old URLs). Error after the importing topics and posts:
importing private messages...
      120 / 120 (100.0%)  [156526 items/min]  /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/mysql2-0.5.1/lib/mysql2/client.rb:131:in `_query': Table 'db.wp_bp_messages_messages' doesn't exist (Mysql2::Error)
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/mysql2-0.5.1/lib/mysql2/client.rb:131:in `block in query'
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/mysql2-0.5.1/lib/mysql2/client.rb:130:in `handle_interrupt'
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/mysql2-0.5.1/lib/mysql2/client.rb:130:in `query'
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/patches/db/mysql2.rb:22:in `query'
	from script/import_scripts/bbpress.rb:505:in `bbpress_query'
	from script/import_scripts/bbpress.rb:453:in `block in import_private_messages'
	from /var/www/discourse/script/import_scripts/base.rb:870:in `block in batches'
	from /var/www/discourse/script/import_scripts/base.rb:869:in `loop'
	from /var/www/discourse/script/import_scripts/base.rb:869:in `batches'
	from script/import_scripts/bbpress.rb:452:in `import_private_messages'
	from script/import_scripts/bbpress.rb:32:in `execute'
	from /var/www/discourse/script/import_scripts/base.rb:46:in `perform'
	from script/import_scripts/bbpress.rb:510:in `<main>'
1 Mi Piace
EDIT: After deeper inspection I found that (at least in my setup) the file was called
  - "templates/import/mysql-dep.template.yml"
NOTE that the correct spelling is “dep”, not “dev”.
Hello! Thanks for posting this. I tried but got this error:
cat: templates/import/mysql-dev.template.yml: No such file or directory
I unfortunately don’t know enough about Docker to proceed…What am I doing wrong? Thank you so much. Here is the full output:
root@forum /var/discourse # ./launcher rebuild import
Fetching origin
remote: Counting objects: 16, done.
remote: Compressing objects: 100% (10/10), done.
remote: Total 16 (delta 12), reused 7 (delta 6), pack-reused 0
Unpacking objects: 100% (16/16), done.
From https://github.com/discourse/discourse_docker
   2ad56e6..d032356  master     -> origin/master
Updating Launcher
Updating 2ad56e6..d032356
Fast-forward
 discourse-setup       | 2 +-
 image/base/Dockerfile | 5 +++--
 launcher              | 4 ++--
 3 files changed, 6 insertions(+), 5 deletions(-)
Fetching origin
Launcher is up-to-date
cd /pups && git pull && /pups/bin/pups --stdin
/usr/bin/docker: invalid reference format: repository name must be lowercase.
See '/usr/bin/docker run --help'.
cat: cids/import_bootstrap.cid: No such file or directory
"docker rm" requires at least 1 argument.
See 'docker rm --help'.
Usage:  docker rm [OPTIONS] CONTAINER [CONTAINER...]
Remove one or more containers
rm: cannot remove 'cids/import_bootstrap.cid': No such file or directory
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
root@forum /var/discourse #support
1 Mi Piace
did you get it resolved? Im too having this error
No. we just manually re-uploaded all of the images.
So I found out the reason for the issue we were having. The import script is breaking when it is trying to get wp_bb_message_message table, that’s happening because you would not have BuddyPress private messages module (which create these table) installed in your WordPress.
I did manage to pass that error by removing the code in bbpress.rb from line 414 to 502
This
 def import_private_messages
puts "", "importing private messages..."
last_post_id = -1
total_posts = bbpress_query("SELECT COUNT(*) count FROM #{BB_PRESS_PREFIX}bp_messages_messages").first["count"]
threads = {}
total_count = bbpress_query("SELECT COUNT(*) count FROM #{BB_PRESS_PREFIX}bp_messages_recipients").first["count"]
current_count = 0
batches(BATCH_SIZE) do |offset|
  rows = bbpress_query(<<-SQL
    SELECT thread_id, user_id
  ORDER BY id
     LIMIT #{BATCH_SIZE}
    OFFSET #{offset}
  SQL
  ).to_a
  break if rows.empty?
  rows.each do |row|
    current_count += 1
    print_status(current_count, total_count, get_start_time('private_messages'))
    threads[row['thread_id']] ||= {
      target_user_ids: [],
      imported_topic_id: nil
    user_id = user_id_from_imported_user_id(row['user_id'])
    if user_id && !threads[row['thread_id']][:target_user_ids].include?(user_id)
      threads[row['thread_id']][:target_user_ids] << user_id
  posts =  bbpress_query(<<-SQL
    SELECT id,
           thread_id,
           date_sent,
           sender_id,
           subject,
           message
      FROM wp_bp_messages_messages
     WHERE id > #{last_post_id}
  ORDER BY thread_id, date_sent
     LIMIT #{BATCH_SIZE}
  SQL
  ).to_a
  break if posts.empty?
  last_post_id = posts[-1]["id"].to_i
  create_posts(posts, total: total_posts, offset: offset) do |post|
    if tcf = TopicCustomField.where(name: 'bb_thread_id', value: post['thread_id']).first
        topic_id: threads[post['thread_id']][:imported_topic_id],
        user_id: user_id_from_imported_user_id(post['sender_id']) || find_user_by_import_id(post['sender_id'])&.id || -1,
        raw: post['message'],
        created_at: post['date_sent'],
    else
      # First post of the thread
        archetype: Archetype.private_message,
        title: post['subject'],
        target_usernames: User.where(id: threads[post['thread_id']][:target_user_ids]).pluck(:username),
        post_create_action: proc do |new_post|
          if topic = new_post.topic
            threads[post['thread_id']][:imported_topic_id] = topic.id
            TopicCustomField.create(topic_id: topic.id, name: 'bb_thread_id', value: post['thread_id'])
          else
            puts "Error in post_create_action! Can't find topic!"
You can also get past it by simply installing buddypress and enabling its private message module.
2 Mi Piace
Thanks for your helpful tutorial , worked fine for me !
Cheers
Sam
Ciao,
grazie per questa guida :slight_smile:
Vengono importati anche gli allegati?
Sembra di sì. C’è una configurazione per la directory degli allegati.
1 Mi Piace
Ciao,
Scusa, ma come generi il file yourbackup.sql? Cosa dovrebbe contenere? Un’esportazione dei database di bbPress?
Grazie
Esatto. Come ottenerlo dipende dagli strumenti che hai a disposizione e da ciò che sai usare.
Un’installazione di bbPress è piuttosto standard: un database WordPress e tutti i post all’interno di wp_posts. Quindi, tutto ciò di cui ho bisogno è eseguire il dump del database dei post di WordPress?
Scusa per la domanda, ma non ho trovato altre istruzioni.
Grazie
Puoi ottenere un dump dell’intero database WordPress oppure esaminare il codice per verificare quali tabelle sono effettivamente utilizzate. È più semplice eseguire il dump dell’intero database.
È difficile consigliare se farlo con mysqump, cPanel, phpMyAdmin o qualche altro strumento.
Funziona (dopo qualche aggiustamento) :slight_smile: :slight_smile: Grazie :wink:
succeed
1 Mi Piace
Ho un errore di connessione al database MySQL durante l’importazione. Il database SQL si trova su localhost. Come posso risolvere questo errore?
/var/www/discourse# su discourse -c “bundle exec ruby script/import_scripts/bbpress.rb”
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mysql2-0.5.3/lib/mysql2/client.rb:90:in `connect’: Impossibile connettersi al server MySQL locale tramite il socket ‘/var/run/mysqld/mysqld.sock’ (2) (Mysql2::Error::ConnectionError)
Grazie.
Se il server MySQL è in esecuzione sul server e non nel contenitore, prova a utilizzare l’indirizzo IP dell’host.
MySQL è in esecuzione in un container dove è attivo anche Discourse. Sembra che lo script di importazione dal container di Discourse non riesca a connettersi al container MySQL. Cosa altro posso fare?
Ne sei sicuro? Puoi connetterti ad esso con lo strumento a riga di comando mysql dall’interno del container?
1 Mi Piace
Ho risolto quel problema. Stavo usando localhost, poi ho capito che l’indirizzo IP per MySQL doveva essere ottenuto da:
Prossimo problema con lo script di importazione..
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mysql2-0.5.3/lib/mysql2/client.rb:90:in `connect’: Plugin caching_sha2_password could not be loaded: /usr/lib/x86_64-linux-gnu/mariadb19/plugin/caching_sha2_password.so: cannot open shared object file: No such file or directory (Mysql2::Error::ConnectionError)
Ho usato il comando ALTER per modificare la password.
Soluzione al problema sopra: è stato eseguito nuovamente il seguente comando.
ALTER USER 'root' IDENTIFIED WITH mysql_native_password BY 'nuovapassword';
1 Mi Piace
Dopo aver applicato alcune delle varie soluzioni postate sopra per risolvere i problemi di esecuzione dell’importatore, non vedo che vengano importati effettivamente nessun post. Avete qualche idea sul perché ottenga una connessione riuscita al nuovo database ma nessun post venga importato?
Sto cercando di importare alcune centinaia di post da un sito WordPress (5.7) che non utilizza bbPress in un sito Discourse già attivo, che contiene anch’esso alcune centinaia di post (2.7.0-beta5).
Il database importato sembra esistere:
mysql> show tables;
| wp_commentmeta        |
| wp_comments           |
| wp_links              |
| wp_options            |
| wp_postmeta           |
| wp_posts              |
| wp_term_relationships |
| wp_term_taxonomy      |
| wp_termmeta           |
| wp_terms              |
| wp_usermeta           |
| wp_users              |
Output durante l'esecuzione dell'importatore:
/var/www/discourse# su discourse -c "bundle exec ruby script/import_scripts/bbpress.rb"
Caricamento gruppi esistenti...
Caricamento utenti esistenti...
Caricamento categorie esistenti...
Caricamento post esistenti...
Caricamento argomenti esistenti...
Importazione utenti...
Importazione utenti anonimi...
Importazione categorie...
Importazione argomenti e post...
Importazione allegati da 'postmeta'...
Creazione permalink...
Aggiornamento stato argomento
Aggiornamento bumped_at sugli argomenti
Aggiornamento last posted at sugli utenti
Aggiornamento last seen at sugli utenti
Aggiornamento first_post_created_at...
Aggiornamento post_count utente...
Aggiornamento topic_count utente...
Aggiornamento digest_attempted_at utente...
Aggiornamento utenti argomento
Aggiornamento tempistiche post
Aggiornamento utenti argomento in evidenza
Aggiornamento argomenti in evidenza nelle categorie
        6 / 6 (100.0%)  [1771 elementi/min]  ]
Reset contatori argomento
Completato (00h 00min 00sec)
