User card loading failed
After the version update, I found that I couldn’t load the user card by clicking on the user’s avatar, and when I entered the personal information settings, it prompted that the page could not be found.
I updated yesterday and User Cards are loading fine for me.
Check safe mode. If that’s ok, then maybe you have an issue in one of your Themes or Theme Components?
Could you please provide any console errors.
I’m in safe mode and still can’t load, here’s my log information
Failed to handle exception in exception app middleware : ActiveRecord::StatementInvalid : PG::UndefinedTable: ERROR: relation "gamification_leaderboard_cache_1_all_time" does not exist LINE 1: ...p.t
ActiveRecord::StatementInvalid (PG::UndefinedTable: ERROR: relation "gamification_leaderboard_cache_1_all_time" does not exist LINE 1: ...p.total_score, p.position FROM "users" INNER JOIN gamificati.
That may have a bearing, but I was referring to browser logs, can you share those?
ie the Browser console. (often opened by F12)
topic-creator-avatar.hbr:1  [THEME 300 'Latest Theme Summary'] Compile error: unknown file extension 'hbr' (discourse/connectors/topic-list-before-columns/topic-creator-avatar.hbr)
(anonymous) @ topic-creator-avatar.hbr:1
[New] Use Copilot in Edge to explain console errors: Click
         to explain the error.
        Learn more
        Don't show again
composer-action-title.js:62 ℹ️ Discourse v3.5.0.beta5-dev — https://github.com/discourse/discourse/commits/7820dd2b8f — Ember v5.12.0
post-placeholder.js:53  [PLUGIN discourse-chain-topics] Deprecation notice: Defining connector classes via registerConnectorClass is deprecated. See https://meta.discourse.org/t/32727 for more modern patterns. [deprecation id: discourse.register-connector-class-legacy]
o @ post-placeholder.js:53
p @ topic-link.js:12
registerConnectorClass @ group.js:15
(anonymous) @ topic-custom-field-initializer.js:32
e1 @ group.js:15
initialize @ topic-custom-field-initializer.js:13
(anonymous) @ composer-action-title.js:62
(anonymous) @ item.js:166
e.each @ form-template-validation.js:54
e.walk @ form-template-validation.js:54
e.topsort @ form-template-validation.js:54
_runInitializer @ item.js:166
runInstanceInitializers @ item.js:166
_bootSync @ composer-action-title.js:62
didBecomeReady @ index.js:93
invoke @ client-error-handler.js:88
flush @ client-error-handler.js:88
_end @ client-error-handler.js:88
(anonymous) @ client-error-handler.js:88
Promise.then
flush @ bookmark.js:114
_scheduleAutorun @ client-error-handler.js:88
_ensureInstance @ client-error-handler.js:88
schedule @ client-error-handler.js:88
f @ bookmark.js:114
waitForDOMReady @ index.js:93
init @ index.js:93
_ @ caret-position.js:86
create @ caret-position.js:86
(anonymous) @ start-app.js:4
(anonymous) @ discourse-boot.js:13
(anonymous) @ topic-custom-field-initializer.js:83
e1 @ group.js:15
Promise.then
f @ bookmark.js:114
init @ index.js:93
(anonymous) @ topic-custom-field-initializer.js:141
e1 @ group.js:15
Promise.then
f @ bookmark.js:114
init @ index.js:93
discourse-home-page.js:79  discourse-home-page error: invalid path ""
s @ discourse-home-page.js:79
initialize @ discourse-home-page.js:42
Promise.then
f @ bookmark.js:114
init @ index.js:93
one-version.js:10  DEPRECATION: Components with separately resolved templates are deprecated. Migrate to either co-located js/ts + hbs files or to gjs/gts. Tried to lookup 'template:components/sidebar-theme-toggle'. [deprecation id: component-template-resolving] This will be removed in ember-source 6.0.0. See https://deprecations.emberjs.com/id/component-template-resolving for more details.
(anonymous) @ one-version.js:10
(anonymous) @ base.js:71
(anonymous) @ deprecate.js:100
l @ index.js:49
(anonymous) @ render-tags.js:60
u @ index.js:49
(anonymous) @ bookmark.js:114
(anonymous) @ form-template-validation.js:54
s @ post-placeholder.js:53
r @ base.js:71
c @ deprecate.js:100
k @ upload.js:65
h @ binary.js:7
(anonymous) @ theme-setting.js:6
lookupComponent @ theme-setting.js:6
A @ theme-setting.js:6
o @ theme-setting.js:6
compile @ theme-setting.js:6
ef @ theme-setting.js:6
compile @ backup-codes.js:33
(anonymous) @ backup-codes.js:33
evaluate @ backup-codes.js:33
evaluateSyscall @ backup-codes.js:33
evaluateInner @ backup-codes.js:33
evaluateOuter @ backup-codes.js:33
next @ backup-codes.js:33
_execute @ backup-codes.js:33
sync @ backup-codes.js:33
tA @ backup-codes.js:33
_renderRoots @ theme-setting.js:6
_renderRootsTransaction @ theme-setting.js:6
_renderRoot @ theme-setting.js:6
_appendDefinition @ theme-setting.js:6
appendOutletView @ theme-setting.js:6
Promise.then
Promise.then
Promise.then
Promise.then
Promise.then
Promise.then
Promise.then
f @ bookmark.js:114
init @ index.js:93
includes.js?v=116e2a6fd81c286e004e2a0afb03baa1:840
            GET https://www.tometo.me/u/shen_hualuo/card.json 500 (Internal Server Error)
(anonymous) @ includes.js?v=116e2a6fd81c286e004e2a0afb03baa1:840
send @ jquery.js:7408
ajax @ jquery.js:7408
a @ base.js:71
(anonymous) @ named-references.js:49
e @ named-references.js:49
A @ base.js:71
(anonymous) @ moment.js:257
(anonymous) @ group.js:15
getAndRemove @ group.js:15
findDetails @ moment.js:257
findByUsername @ moment.js:257
_showCallback @ item.js:166
(anonymous) @ topic-link.js:12
_runExpiredTimers @ client-error-handler.js:88
setTimeout
setTimeout @ client-error-handler.js:88
_installTimerTimeout @ client-error-handler.js:88
_reinstallTimerTimeout @ client-error-handler.js:88
_later @ client-error-handler.js:88
T @ bookmark.js:114
_show @ topic-link.js:12
_showCardOnClick @ topic-link.js:12
_cardClickHandler @ topic-link.js:12
_run @ client-error-handler.js:88
_join @ client-error-handler.js:88
p @ bookmark.js:114
includes.js?v=116e2a…04e2a0afb03baa1:840
 GET https://www.tometo.me/u/shen_hualuo.json 500 (Internal Server Error)
(anonymous)	@	includes.js?v=116e2a…04e2a0afb03baa1:840
a	@	base.js:71
A	@	base.js:71
afterModel	@	post-placeholder.js:53
runAfterModelHook	@	topic-link.js:12
k	@	named-references.js:49
w	@	named-references.js:49
Promise.then
(anonymous)	@	hashtag-autocomplete.js:158
T	@	named-references.js:49
resolve	@	topic-link.js:12
T	@	form-template-validation.js:54
getTransitionByIntent	@	topic-link.js:12
transitionByIntent	@	topic-link.js:12
doTransition	@	topic-link.js:12
transitionTo	@	topic-link.js:12
_doTransition	@	upload.js:65
transitionTo	@	binary.js:7
l	@	UIPlugin.js:138
click
So I don’t believe you were in safe mode.
This component seems to be causing an issue:
topic-creator-avatar.hbr:1  [THEME 300 '最新主题摘要'] Compile error: unknown file extension 'hbr' (discourse/connectors/topic-list-before-columns/topic-creator-avatar.hbr)
(匿名) @ topic-creator-avatar.hbr:1
That’s because hbr (raw) templates are no longer supported.
Raise with the author of that Theme.
@manuel didn’t you encounter this one as well?
So these look related.
Looks like Gamification is modifying the User data and is throwing an error.
So that almost certainly explains why the User Card is not loading.
It looks to me like you have more than one issue and are related to addins, not Core Discourse.
I would remove:
  • Gamification plugin
  • Whatever theme component ([THEME 300 ‘最新主题摘要’]) is causing that other browser error (needs to be rewritten to avoid use of .hbr templates)
until you can solve those issues.
Suggest reporting the Gamification error on the Gamification Topic.
As it’s an official plugin you can also report a bug in the Contribute > Bug category (though remember to add the gamification tag). :partying_face:
That’s true.
In any case this Topic is now dealing with two issues, and they should probably be broken out into two.
The user card not loading is most likely a Gamification issue though, so perhaps use this one for that. gamification tag added.
(ok so THAT’S confusing the Topic meta editing interface has changed!)
Yes.
Screenshot From 2025-05-13 11-54-39
That was when I tried installing a backup. Accessing user-cards and user-pages failed until I deleted the leaderboard from the backup.
edit: on a different note, it seems my screenshot doesn’t open in a lightbox? The upload was 1693px wide, but it only shows in 690.
That seems very Draconian. I wonder if there is a lighter weight solution?
This looks potentially related:
https://github.com/discourse/discourse-gamification/commit/19a4cc7c0bdc60f2b3c1eb747e80fd6211005874
Yes, weird, original here for people who want to actually be able to read it :slight_smile:
It might be. This migration deletes versioned cache views that have _x tacked to the end (where x is a digit). But the table that it misses is an unversioned table (without _x).
@sheng_hualuo can you try running this from a rails console?
DiscourseGamification::LeaderboardCachedView.regenerate_all
gamification_leaderboard_cache_1_all_time isn’t 1 the version?
I think for some reason the naming convention was changed.
No, that’s the leaderbord id. It’s all explained in the commit message of the commit you mentioned.
Also, look at the regex 'gamification_leaderboard_cache_[0-9]+_[a-zA-Z_]+_[1-9]$'
Ah, that all starts to make sense. So the versioned version (ahem) was dropped, but for some reason the new version (ahem) has not been materialised.
I don’t have the full trace, but I believe the error happens during gamification_score serialization for the user card.
Given the transient nature of these materialized views, a score lookup isn’t expected to cause a system-wide error, it should fall back to a “default score” when the view doesn’t exist.
There’s a bug in the materialized view existence check. It reports that a view exists when it actually doesn’t (at least not in the current public schema), which leads to a lookup on a non-existent view resulting in the error.
I think what happened here was, the materialized view was present in the backup schema created as part of the restore but not the public schema. The backup schema is retained for a while after the restore.
I’ve got a PR ready with a fix.
https://github.com/discourse/discourse-gamification/pull/203
