Earlier this week I updated from 2.7.0.beta2 to 2.8.0.beta2. Since then my regular account (but not my admin account) cannot get to any of my /u/ pages. I get a 404 error instead. This happens on desktop (Firefox 84 and 89) and mobile (tested on Android), and after logging out, clearing cache, and returning.
I suspect this change is related to the issue:
I have had the discourse-user-card-badges plugin installed (it shows as version 0.1) since well before this update and that change plus the error below make me think maybe the plugin doesnāt play nice with the changes? If so, shouldnāt the update disable the plugin or ask me to disable it?
activemodel (6.1.3.2) lib/active_model/attribute_methods.rb:469:in `method_missing'
plugins/discourse-user-card-badges/plugin.rb:40:in `block (2 levels) in activate!'
(eval):93:in `_fast_attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:468:in `rescue in attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:455:in `attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:343:in `as_json'
activesupport (6.1.3.2) lib/active_support/json/encoding.rb:22:in `encode'
activesupport (6.1.3.2) lib/active_support/core_ext/object/json.rb:43:in `to_json'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:331:in `to_json'
multi_json (1.15.0) lib/multi_json/adapters/oj.rb:56:in `dump'
multi_json (1.15.0) lib/multi_json/adapter.rb:25:in `dump'
multi_json (1.15.0) lib/multi_json.rb:139:in `dump'
app/controllers/application_controller.rb:519:in `render_json_dump'
app/controllers/users_controller.rb:94:in `block (2 levels) in show'
actionpack (6.1.3.2) lib/action_controller/metal/mime_responds.rb:214:in `respond_to'
app/controllers/users_controller.rb:86:in `show'
actionpack (6.1.3.2) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (6.1.3.2) lib/abstract_controller/base.rb:228:in `process_action'
actionpack (6.1.3.2) lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack (6.1.3.2) lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport (6.1.3.2) lib/active_support/callbacks.rb:117:in `block in run_callbacks'
app/controllers/application_controller.rb:395:in `block in with_resolved_locale'
i18n (1.8.10) lib/i18n.rb:314:in `with_locale'
app/controllers/application_controller.rb:395:in `with_resolved_locale'
activesupport (6.1.3.2) lib/active_support/callbacks.rb:126:in `block in run_callbacks'
activesupport (6.1.3.2) lib/active_support/callbacks.rb:137:in `run_callbacks'
actionpack (6.1.3.2) lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack (6.1.3.2) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (6.1.3.2) lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
activesupport (6.1.3.2) lib/active_support/notifications.rb:203:in `block in instrument'
activesupport (6.1.3.2) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (6.1.3.2) lib/active_support/notifications.rb:203:in `instrument'
actionpack (6.1.3.2) lib/action_controller/metal/instrumentation.rb:33:in `process_action'
actionpack (6.1.3.2) lib/action_controller/metal/params_wrapper.rb:249:in `process_action'
activerecord (6.1.3.2) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (6.1.3.2) lib/abstract_controller/base.rb:165:in `process'
actionview (6.1.3.2) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (2.3.2) lib/mini_profiler/profiling_methods.rb:85:in `block in profile_method'
actionpack (6.1.3.2) lib/action_controller/metal.rb:190:in `dispatch'
actionpack (6.1.3.2) lib/action_controller/metal.rb:254:in `dispatch'
actionpack (6.1.3.2) lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
actionpack (6.1.3.2) lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack (6.1.3.2) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (6.1.3.2) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (6.1.3.2) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (6.1.3.2) lib/action_dispatch/routing/route_set.rb:842:in `call'
lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
rack (2.2.3) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.3) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.3) lib/rack/head.rb:12:in `call'
actionpack (6.1.3.2) lib/action_dispatch/http/permissions_policy.rb:22:in `call'
lib/middleware/anonymous_cache.rb:355:in `call'
rack (2.2.3) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.3) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (6.1.3.2) lib/action_dispatch/middleware/cookies.rb:689:in `call'
actionpack (6.1.3.2) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (6.1.3.2) lib/active_support/callbacks.rb:98:in `run_callbacks'
actionpack (6.1.3.2) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (6.1.3.2) lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
actionpack (6.1.3.2) lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
actionpack (6.1.3.2) lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster (2.9.6) lib/logster/middleware/reporter.rb:43:in `call'
railties (6.1.3.2) lib/rails/rack/logger.rb:37:in `call_app'
railties (6.1.3.2) lib/rails/rack/logger.rb:28:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
actionpack (6.1.3.2) lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack (6.1.3.2) lib/action_dispatch/middleware/request_id.rb:26:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
rack (2.2.3) lib/rack/method_override.rb:24:in `call'
actionpack (6.1.3.2) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.3) lib/rack/sendfile.rb:110:in `call'
actionpack (6.1.3.2) lib/action_dispatch/middleware/host_authorization.rb:92:in `call'
rack-mini-profiler (2.3.2) lib/mini_profiler/profiler.rb:249:in `call'
message_bus (3.3.6) lib/message_bus/rack/middleware.rb:61:in `call'
lib/middleware/request_tracker.rb:177:in `call'
railties (6.1.3.2) lib/rails/engine.rb:539:in `call'
railties (6.1.3.2) lib/rails/railtie.rb:207:in `public_send'
railties (6.1.3.2) lib/rails/railtie.rb:207:in `method_missing'
rack (2.2.3) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.3) lib/rack/urlmap.rb:58:in `each'
rack (2.2.3) lib/rack/urlmap.rb:58:in `call'
unicorn (6.0.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.0.0) lib/unicorn/http_server.rb:732:in `worker_loop'
unicorn (6.0.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.0.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.0.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/2.7.0/bin/unicorn:23:in `load'
vendor/bundle/ruby/2.7.0/bin/unicorn:23:in `<main>'
