User edits his last comment, gets "composer was opened without a draft key"
One of my users use an iPhone and Safari. When he tried to edit his posts he gets the message “composer was opened without a draft key”.
Some specifics according to himself:
If I try to edit a comment and it happens again, I’ll keep you informed. It actually has happened 5 or 6 times. However, let’s say I go up to another comment in the same thread, I have no issues with editing previous comments. Only happens on the last comment I have made in the thread. Weird!
Link to thread:
I’m on v1.3.0.beta3 +19 (GitHub - discourse/discourse at 399418e1ff186651cedb3044f7d807b8105e670f)
1 curtida
Weird, we have not seen this one in ages. We have seen tremendous amounts of problems with latest builds of safari on ios so it may be related.
I will have a look to see if there is any extra protection we can add.
Has happened to me too on Chrome beta 42 on Android on meta. I was also editing a comment or so, I can’t quite remember.
Screenshot taken on 2015-03-12.
Can you work out a repro on try, an exact repro would make it easy to solve
I suspect it is some kind of new regression, we have not seen this in ages but I heard it reported on community.imgur as well recently.
I was able to reproduce it easily:
Create a new thread, editing this post works.
Reply to the OP, the page seems to reload a bit and the composer error pops up after tapping on edit.
This error pops up as many times as you hit the edit icon, reloading the site fixes this.
Post a reply to some comment and the same thing happens as above.
I tried replying to someone else’s comment but editing that works fine. Got the bug replying to an OP. Not sure.
3 curtidas
awesome, will fix first thing tomorrow
So this is an android chrome mobile issue only right ?
Possible, I believe the imgur report looked like Android Chrome to me as well.
Well, OP’s user had this bug appear on his Safari/iPhone.
Can anybody try to repro what I did but on Safari?
this should be fixed per:
5 curtidas
