Using a CASE expression to order results
I don’t think it’s possible to pass a keyword as a parameter, but a boolean :desc parameter could be used in a CASE expression.
--[params]
-- boolean :desc = false
SELECT
FROM generate_series(1, 10) AS num
ORDER BY
  CASE WHEN :desc THEN num END DESC,
  CASE WHEN NOT :desc THEN num END ASC
