I wonder if any experienced user/dev can give me some light here? I want to limit trust_levels usint badges and/or automation and I see it’s not possible out of the box.
Trying to get this done I found that API calls can lock or unlock the trust_level on users, so it could work?
Any advice or suggestion would be greatly appreciated.
Yes, you got it right: you can’t directly limit the trust level through badges or automation, but you can through the API. If you create a condition (for example, getting a badge), you can call the API with a script to change the trust_level and fix it. It’s not out of the box, but it works
