That’s great, but I would like to personalize my Typeforms using hidden fields. If the Discourse username could be added to the url, then I could use it in the form. So when I visit, the url would be:
Here is my (somewhat clumsy) solution, in case it helps someone. I added this code under Admin > Customize > Themes > Edit CSS/HTML > /head:
api.decorateCooked($elem => {
var i, j;
var selector = 'https://example.typeform.com';
// seems like this should work but it doesn't:
// var typeforms = $elem[0].querySelectorAll('src^=[' + selector + ']');
var ps = $elem[0].querySelectorAll('p');
for (i=0; i<ps.length; i++) {
p = ps[i];
var iframes = p.querySelectorAll('iframe');
for (j=0; j<iframes.length; j++) {
var iframe = iframes[j];
if (iframe.src.startsWith(selector)) {
var oldsrc = iframe.getAttribute('src');
var username = api.getCurrentUser()['username'];
var newsrc = oldsrc + '?username=' + username;
iframe.setAttribute('src', newsrc);
</script>
Then add a Hidden Field “username” in your Typeform. The username can be used in your form, and will also be sent to the destination (integrations or webhook) when the user hits Submit.
When you get the Typeform link to embed in Discourse, it will be something like:
قم بتضمين Typeform الخاص بك في منشورك ببساطة عن طريق مشاركة الرابط. لا تستخدم ميزة تضمين Typeform. ستحتاج أيضًا إلى السماح بعنوان URL الخاص بـ Typeform https://forms.typeform.com كتضمين في إعدادات المسؤول لديك.
