Using nginx as proxy server is very slow, but it is very fast if using nginx in docker! Why?
app.yml
templates:
  #- "templates/postgres.template.yml"
  - "templates/sshd.template.yml"
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
  - "templates/web.socketed.template.yml"
expose:
  #- "8080:80"   # http
  #- "444:443" # https
params:
  db_shared_buffers: "780MB"
  # db_work_mem: "512MB"
  version: stable
env:
  # 数据库配置
  DISCOURSE_DB_USERNAME: ****
  DISCOURSE_DB_PASSWORD: ***
  DISCOURSE_DB_HOST: ***
  DISCOURSE_DB_NAME: ***
  DISCOURSE_DB_PORT: ***
  DISCOURSE_DB_BACKUP_PORT: ***
  LANG: zh_CN.UTF-8
  DISCOURSE_DEFAULT_LOCALE: zh_CN
  UNICORN_WORKERS: 2
nginx config
server {
    listen 80; listen [::]:80;
    server_name my.web.org;
    return 301 https://$host$request_uri;
server {
    listen 443 ssl http2;  listen [::]:443 ssl http2;
    server_name minetest.cosoc.org;
    ssl_certificate      /var/discourse/shared/standalone/ssl/my.web.org.cer;
    ssl_certificate_key  /var/discourse/shared/standalone/ssl/my.web.org.key;
    ssl_session_tickets off;
    http2_idle_timeout 5m; # up from 3m default
location / {
        proxy_pass http://unix:/var/discourse/shared/standalone/nginx.http.sock;
        proxy_set_header Host $http_host;
        proxy_http_version 1.1;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Proto https;
        proxy_set_header X-Real-IP $remote_addr;
Why is nginx acting so slowly??? But it’s fast when you don’t use it!!
