Are there any steps that need to be adjusted for using the multiple container setup that splites out redis/postgres in to data and the rest in to web_only? I’ve only added the plugin to the web_only container config.
I have the official dashboard set up in grafana and Redis RSS and Postgres Size are both N/A.
Container CPU usage and Container Memory Usage are No data but that might be from missing cadvisor on the host?
Not necessarily, but I guess it depends on what you are using to do the regex comparison.
#!/usr/bin/env bash
TARGET="10.20.20.5"
TARGET2="10.20.20.50"
if [[ "^10.20.20.5$" =~ $TARGET ]]; then
echo "TARGET Matched Non-escaped"
fi
if [[ "^10.20.20.5\$" =~ $TARGET ]]; then
echo "TARGET Matched escaped"
fi
if [[ "^10.20.20.5$" =~ $TARGET2 ]]; then
echo "TARGET2 Matched Non-escaped"
fi
if [[ "^10.20.20.5\$" =~ $TARGET2 ]]; then
echo "TARGET2 Matched escaped"
fi
