It would be great if script support was added to this plugin.
This would help to use some advertising platforms that are not supported by the plugin.
3 לייקים
The challenge here, I suspect, is there are so many different providers of “scripts” with, for example, different ad id systems.
This is already possible, but you currently have to develop the solution yourself.
I have done this for clients.
If you have budget, suggest Marketplace (a reasonable suggestion I feel because this is directly a revenue earning modification)
4 לייקים
