Using subject line for reply-by-email identifier
precessor reported successfully setting up reply-by-email but sought a way to use their own domain instead of Gmail.com. They attempted to use a DNS email forwarder to preserve the sub-address (address tag) but discovered this was not possible via standard forwarding. Consequently, they proposed a feature request: Discourse should include the unique string identifier in the reply email’s subject line in addition to the address tag, allowing users to rely on subject line parsing as a workaround without needing a dedicated email server. DeanMarkTaylor clarified that while the To: header remains unchanged during forwarding, Discourse only considers To:, CC:, and BCC: headers. However, they provided specific guides on how to configure forwarding to utilize a custom domain effectively, referencing previous discussions on the topic. precessor responded with gratitude, noting that the provided solution was exactly what they needed.
I just set up the reply-by-email function as described here:
It’s working great! :laughing: :thumbsup:
For appearances, I prefer to have the reply domain at my domain rather than Gmail.com, so I thought about setting up a DNS email forwarder. I hoped that the sub address (address tag) would be preserved.I would continue to POP3 from Gmail, I don’t mind that.
However, this does not seem to be possible:
http://webmasters.stackexchange.com/q/92236/62822
But a workaround remains, as described in that post: put the string identifier in the subject line as well (and look for it there as well). This would prevent Discourse customers needing to set up their own email server, which is my remaining option (I’m using a DigitalOcean droplet).
May I therefore suggest this feature: put the string identifier if a reply-by-email in the subject line as well as the address tag, and check for it there too.
When automatically forwarding the “To:” email address doesn’t change, only the “Delivered-To:” is changed.
The “To:”, “CC:”, “BCC:” are the only email header values considered in Discourse.
I describe how to setup forwarding in a way that uses a custom domain here:
https://meta.discourse.org/t/set-up-reply-via-email-support/14003/48?u=deanmarktaylor
And here:
https://meta.discourse.org/t/set-up-reply-via-email-support/14003/50?u=deanmarktaylor
3 إعجابات
I didn’t see that - just what I need! Thanks for posting :smile:
إعجاب واحد (1)
