Vagrant based server failing on db:migrate
The discussion revolves around an error encountered when trying to run rake db:migrate on a Vagrant-based server, resulting in a NameError due to an uninitialized constant SiteSettings::DbProvider::RailsMultisite.
The issue has been reported by kcoop and has been encountered by others, including simon when running the command on a Vagrant image on a Mac.
Several workarounds have been suggested, including using a different setup for development as outlined in an article mentioned by simon and running a command to change the permissions of the rails_multisite gem files as suggested by mpalmer and OnceWas.
The command to change permissions is:
sudo chmod -R a+r /var/lib/gems/2.2.0/gems/rails_multisite-1.0.2
Note: As of October 23, the version of rails_multisite may need to be updated.
I just ran through the instructions in the developer guide to install an environment using a virtual machine with vagrant I found here.
In my newly created instance, after a bundle update, updating the database with rake like so
bundle exec rake db:migrate
generates the following error:
rake aborted!
NameError: uninitialized constant SiteSettings::DbProvider::RailsMultisite
/vagrant/lib/site_settings/db_provider.rb:52:in `current_site'
/vagrant/lib/site_setting_extension.rb:44:in `current'
/vagrant/lib/site_setting_extension.rb:96:in `block in setting'
/vagrant/lib/site_setting_extension.rb:93:in `synchronize'
/vagrant/lib/site_setting_extension.rb:93:in `setting'
/vagrant/lib/site_setting_extension.rb:151:in `client_setting'
/vagrant/app/models/site_setting.rb:18:in `block in load_settings'
/vagrant/lib/site_settings/yaml_loader.rb:29:in `block (2 levels) in load'
/vagrant/lib/site_settings/yaml_loader.rb:20:in `each'
/vagrant/lib/site_settings/yaml_loader.rb:20:in `block in load'
/vagrant/lib/site_settings/yaml_loader.rb:19:in `each_key'
/vagrant/lib/site_settings/yaml_loader.rb:19:in `load'
/vagrant/app/models/site_setting.rb:16:in `load_settings'
/vagrant/app/models/site_setting.rb:25:in `<class:SiteSetting>'
/vagrant/app/models/site_setting.rb:4:in `<top (required)>'
/vagrant/config/initializers/04-message_bus.rb:39:in `<top (required)>'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/engine.rb:652:in `block in load_config_initializer'
/var/lib/gems/2.2.0/gems/activesupport-4.2.4/lib/active_support/notifications.rb:166:in `instrument'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/engine.rb:651:in `load_config_initializer'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/engine.rb:616:in `block (2 levels) in <class:Engine>'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/engine.rb:615:in `each'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/engine.rb:615:in `block in <class:Engine>'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/initializable.rb:30:in `instance_exec'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/initializable.rb:30:in `run'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/initializable.rb:55:in `block in run_initializers'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/initializable.rb:44:in `each'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/initializable.rb:44:in `tsort_each_child'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/initializable.rb:54:in `run_initializers'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/application.rb:352:in `initialize!'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/railtie.rb:194:in `public_send'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/railtie.rb:194:in `method_missing'
/vagrant/config/environment.rb:5:in `<top (required)>'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/application.rb:328:in `require_environment!'
/var/lib/gems/2.2.0/gems/railties-4.2.4/lib/rails/application.rb:457:in `block in run_tasks_blocks'
Tasks: TOP => db:migrate => environment
I cloned the github repo from the instructions, and it’s pristine. Is this a bug? Any thoughts on what I’m doing wrong?
Yes, the same as https://meta.discourse.org/t/upgrade-failed-after-the-recent-todays-commits-cannot-load-such-file-rails-multisite/34396
Thanks, Dmitry. This didn’t show up in my googling. I’ll use sunsijie’s workaround.
Hmm… no joy. The gem was already in my Gemfile, and the chmod had no positive impact (it wasn’t readable by all, FWIW).
Any more thoughts on this?
I solved this by basically wiping all my installed gems and reinstalling all of them. It’s possible you have a bad copy of something. I have no idea what it is, though ¯\_(ツ)_/¯
1 me gusta
I just tried running rake db:migrate on the Vagrant image on a mac and got the same results you are getting.
You might try using the setup outlined in this article for Development. It’s working well.
Thanks, Simon. I’ll try that out.
I’ve tracked down the problem: the rails_multisite gem has restrictive permissions on some of the files, and so the vagrant user can’t read them (and hence can’t load the code).
While @sam is unavailable to make a new (fixed) release of rails_multisite, the simplest workaround is to run the following:
That’ll fix the permissions and you’ll be off and running.
4 Me gusta
As of October 23, you’ll need to bump up the rails_multisite version:
