"Aguardando o unicórnio recarregar", então a atualização para
What are the hardware specs? Is it heavily memory constrained, or are the disks slow (not SSD)?
It’s not a problem to update via SSH command line if that works better, but it shouldn’t be required.
I’m not sure what the criteria is for constrained, the site has been relatively speedy (with no cloudflare, CDN or other tricks). It’s a KVM VM with 2GB. Here is an output from free:
              total        used        free      shared  buff/cache   available
Mem:        2047876     1263844      121092      280544      662940      325164
Swap:       2097148      549032     1548116
There is nothing else running on this but Discourse. However, the disks are definitely slow, non-SSD, in RAID-10, and shared with a few other VMs. I ran iotop as the nightly backup was going and didn’t see anything above 50MBps.
The exported non-compressed backup .sql is ~600MB, average daily engaged this past month <50, and daily pageviews are <6000 per day.
I do see one major difference in the output between what you posted originally and what @danekhollas and I are getting. In our output, it takes Unicorn significantly longer to reload (based on the number of dots), however it’s always been that way since that was added to the upgrade process.
The swap usage is fairly high there. This implies you have a busy instance. Also, slow disks are going to be quite painful in several dimensions.
In my case I have SSD and plenty RAM, but CPU is slow (1.7 GHz) and I usually have only around 7Gb free space on HDD. I noticed that Discourse seems to want at least 5Gb free during upgrade, could this be the issue?
Note that this problem started happening at a specific point in time (probably around this topic got started but I am not sure) and since then I was not able to upgrade via UI at all, which lead me to believe that something must have changed…
I gave @tgxworld access to my instance in case it is helpful.
Note tgx is out for a bit, he may have a chance to have a quick look next week.
This also just happened to me, however it looks like the Docker Manager upgrade actually worked:
Just to update since my last post ~4 months ago. I took the advice given and moved over to a whole new machine, with a significant RAM+CPU increase and switch to full SSD. This problem has not occurred again.
Também estou enfrentando esse problema nas últimas vezes em que tentei atualizar usando a interface web.
Minha instância está hospedada em uma VM que pode ser configurada com especificações mais altas se eu solicitar, mas não está claro para mim quais são as especificações recomendadas para executar uma instância típica do Discourse.
Alguém pode fornecer essas especificações?
A pergunta acima assume que a falha na atualização ocorre apenas devido à falta de recursos no host.
Preciso de ajuda, estou recebendo um erro ao atualizar o docker_manager
Desculpe, ocorreu um erro ao atualizar o Discourse. Por favor, verifique os logs abaixo.
É o mesmo erro
Iniciando 1(s) worker(es) Unicorn que foram inicialmente parados
A versão é Versão Remota: 2c89085
Tenho a opção de Redefinir Atualização. Devo fazê-lo? Por favor, ajude-me. Agradeço antecipadamente!!
Isso é apenas para relatar que tive esse problema pela primeira vez com a atualização v2.4.0.beta10 +1 (“docker_manager 2c89085 Atualizado”) via interface web. Se alguém precisar do meu log, veja o anexo. Discourse2.4beta10error.txt (10,2 KB)
./launcher rebuild app funcionou normalmente.
Isso ocorreu no meu sistema de teste, auto-hospedado em casa. Intel Atom D525 1,8 GHz, 2 núcleos / 4 threads com 4 GB e SSD rodando Lubuntu 16.04 LTS. Apenas Docker/Discourse, sem outras tarefas.
Esse problema ocorreu comigo quando tentei atualizar para a versão 2.7.4.
Tentei reconstruir via linha de comando, mas obtive o seguinte erro (após executar o discourse-doctor):
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 4115 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
5b36313b3f2b9e2173d52f8a7519d6aba3c4a975182d80150776d9c83659c351
==================== END REBUILD LOG ====================
Failed to rebuild app.
Agora, é estranho que a nova versão 2.7.4 seja exibida e, quando tentei atualizar um componente de tema, recebi a mensagem: “about.json contém valores inválidos: A versão máxima do Discourse é inválida”.
Alguém tem uma recomendação sobre como colocar o Discourse em um estado válido novamente?
