@LaptechInfo, the issue has been fixed; once you upgrade Discourse, this should work!
Thank you. I will check
its working good. now.
but no option to add text as watermark
Thank you
@LaptechInfo That’s the reason. I originally started working with text, but the ability to create/display options in Discourse is limited. You have a lot of tools online where you can easily make an image with text.
You are right. lots of tools are there to create text style.
Great job you have done. I appreciate your work and efforts.
Thanks for your plugin, after adding watermark can I adjust the image quality reduction level?
I think Its not possible.
The watermark is applied client-side before the image is uploaded server-side, so the TC has no control on the final image quality. I believe yo have the following site setting to control it:
But also:
Can you check your browser’s console if you see any errors?
TypeError: NetworkError when attempting to fetch resource.
Do you see only this error? Don’t hesitate to take a screenshot of the console!
Does it work when uploading one image at a time? Or does it fail all the time for any upload?
Interesting
. The component applies the watermark client-side in the background (Web Worker), so I would assume something is happening in this context. I’m unsure what, though.
Does the image preview with your watermark image in the theme settings work without errors?
Hi, I have suggestion. if you could enable the function of watermark on Discourse channels also.
that will be a great feature.
Thank you ![]()
@Arkshine
On Discourse 3.4.2 image watermark works, but QR Code or text are not added, tried multiple files, hard refresh etc. Anyone else with same issue?
My settings:
Thanks for the report. Let me check again to see if I missed something.
@jrgong One of the issues I noticed is related to the color. The CSS variable in Discourse now uses shorthand color (e.g., #fff instead of #ffffff), but the lib wants the full format.
So in Watermark qrcode color and Watermark qrcode background color, use the full format:
I will update the TC soon.
That fixed it, thx! ![]()
此组件会导致无法上传Gif,如启用此选项上传Gif将自动转为png格式。
Can you not use GIFS and this watermark theme component at the same time?
