Way to find "hot" topics?
At https://community.letsencrypt.org/ we have a lot of “support” posts that are quickly asked and answered in a straightforward way. We also have a few longer-form discussion threads that can sometime get heated. When I have limited time to read, I usually want to see if there are any hot threads with lots of recent posts. Is there an easy way to get this view? If I click “Top,” I get a list of all-time most popular posts. If I sort by “Activity,” I get the threads with the most recent posts, regardless of number of posts.
Thanks,
Jacob
「いいね!」 1
When you select “Top” you have a interval selector, where you can refine to a shorter period, like: Let's Encrypt Community Support
「いいね!」 3
Perfect, I had missed that! Thanks!
このトピックは2517日後に自動的に閉じられました。新しい返信は許可されていません。
