|  | Summary | Professional Telegram bot for automatic notifications about new posts from Discourse forums with AI-generated summaries using OpenAI GPT-4.1-nano |
|  | Repository Link | GitHub - DigneZzZ/webhook_tg_bot |
|  | Install Guide | README_EN.md |
Webhook Telegram Bot - AI-Powered Discourse Notifications
Note: While this is not a traditional Discourse plugin but rather an external integration service, I couldn’t find a more appropriate category to share this useful tool with the Discourse community. This bot works alongside your Discourse forum to provide enhanced notification capabilities.
Features
 Discourse Integration
Processes webhooks for topic and post creation events
Supports all types of Discourse content
Combines topic and post data into unified messages
Webhook signature verification for security (HMAC-SHA256)
 AI Content Analysis
 AI Content Analysis
OpenAI GPT-4.1-nano integration for intelligent post summaries
Context-aware content analysis with HTML cleanup
Special templates for different content types
Automatic content filtering and processing
 Advanced Telegram Delivery
Send notifications to main chat or specific forum topics
Category mapping - route different Discourse categories to different Telegram topics
User role emoji prefixes (  Admin, Admin, Moderator, Moderator, Staff, etc.) Staff, etc.)
Smart HTML message formatting
 Flexible Filtering & Control
Monitor specific categories or all categories
Ignore unwanted categories with priority system
Block bot users (discobot, chatbot, system users)
Premium section notifications with subscription alerts
 Production Ready
 Production Ready
Docker containerization with health checks
GitHub Actions CI/CD pipeline
Systemd integration for auto-startup
Comprehensive logging and monitoring
Graceful shutdown and error handling
Configuration
1. Discourse Webhook Setup
Navigate to Admin → API → Webhooks
Click New Webhook
Configure:
Payload URL: https://your-domain.com/webhook
Content Type: application/json
Secret: your_webhook_secret
Which events: Topic Event + Post Event
2. Telegram Bot Setup
Create bot via @BotFather
Get Chat ID for your group/channel
Optionally set up forum topics for category routing
3. Environment Configuration
Create .env file with required settings (see full configuration in repository).
4. Docker Deployment
# Quick installation
curl -fsSL https://raw.githubusercontent.com/dignezzz/webhook_tg_bot/main/install.sh -o install.sh
chmod +x install.sh
./install.sh install
5. Reverse Proxy Setup
For webhook support on your domain, configure reverse proxy (nginx/Apache) to route webhook requests to the bot container on port 8080.
Example nginx configuration:
location /webhook {
proxy_pass http://localhost:8080/webhook;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
Settings
| Name | Description | Default | Required |
| TELEGRAM_BOT_TOKEN | Bot token from @BotFather | - |  |
| TELEGRAM_CHAT_ID | Target group/channel ID | - |  |
| TELEGRAM_THREAD_ID | Main topic ID (0 = main chat) | 0 |  |
| WEBHOOK_SECRET | Secret key for signature verification | - |  |
| WEBHOOK_PORT | Webhook server port | 8080 |  |
| WEBHOOK_PATH | Webhook endpoint path | /webhook |  |
| OPENAI_API_KEY | OpenAI API key for summaries | - |  |
| OPENAI_MODEL | GPT model to use | gpt-4.1-nano |  |
| BASE_URL | Your Discourse forum URL | - |  |
| MONITORED_CATEGORIES | Category IDs to monitor (comma-separated) | all |  |
| IGNORED_CATEGORIES | Category IDs to ignore (comma-separated) | none |  |
| IGNORED_USERS | User IDs to ignore (comma-separated) | none |  |
| PREMIUM_CATEGORIES | Premium category IDs (comma-separated) | none |  |
Category-to-Topic Mapping (Optional):
TELEGRAM_THREAD_ID_1=123456
THREAD_CATEGORIES_1=1,2,3
TELEGRAM_THREAD_ID_2=234567
THREAD_CATEGORIES_2=4,5
Message Format Example
👤 👑 Administrator created a new post: Docker Configuration Guide
📋 Author shares a solution to Docker container configuration problem and explains step-by-step process of fixing database connection errors.
🔗 Topic link (https://forum.example.com/t/topic/123)
🏷 Tags: #docker, #database, #troubleshooting
💎 This section is available by subscription only.
Installation & Management
The bot includes a management script for easy operations:
whtg status # Check bot status
whtg start # Start the bot
whtg stop # Stop the bot
whtg restart # Restart the bot
whtg logs # View logs
whtg update # Update to latest version
whtg uninstall # Remove the bot
Language Support
Note: Currently, all interface messages and documentation are in Russian, but English language support will be added in the near future. The bot works with any Discourse forum regardless of language.
Technical Requirements
Docker and Docker Compose
Reverse proxy (nginx/Apache) for webhook domain support
OpenAI API key (optional, for AI summaries)
HTTPS certificate (recommended for production)
Support & Contributions
GitHub Repository: GitHub - DigneZzZ/webhook_tg_bot
Issues: Report bugs or feature requests
Discussions: Community discussions
License: MIT License
