Welcome image is on the top of the drop down box
Welcome image is on the top of the drop down box.
I was using Google Chrome when I found this.
Can you repro this problem here on meta or try.discourse.org?
I just tried now Jeff, however there is no dropdown box on the signup forum. I believe that it is only the dropdown that is hidden by the welcome image.
Regards
What is your theme? With Light theme i have no problem. I have 3 dropdowns.
I can repro the problem and will see if there’s a way to fix it… it’s most obvious on a very short screen when there are a lot of options in the dropdown.
@ufukayyildiz Im using light theme yes.
Yes I have a long list of all countries…
