What adjustments are needed when discourse uses a non-443 port?
Some of the issues I found include email failure, and users are also redirected to an unreachable interface after registration.
Additionally, the default post image wall is also disabled, and none of the uploaded images can be loaded.
Even after changing it to port 3443, I found that the Discourse logo cannot be loaded.
It seems that many problems have occurred
Is there a way to fix it with one click? Thank youSome of the issues I found include email failure, and users are also redirected to an unreachable interface after registration.
Is there a way to fix it with one click? Thanks
I haven’t tried adding these in env yet
DISCOURSE_PORT: 3443
DISCOURSE_FORCE_HTTPS: true
Don’t know if it will be useful after adding
After changing the port, many images fail to load properly, for example https://mydomain/uploads/default/optimized/1X/_129430568242d1b7f853bb13ebea28b3f6af4e7_2_32x32.png fails to load
But when I manually change it to https://mydomain:3443/uploads/default/optimized/1X/_129430568242d1b7f853bb13ebea28b3f6af4e7_2_32x32.png it can load
But there are too many places where 3443 needs to be added. Is there a quick way to modify it? 443 is not availableI haven’t tried adding these in env yet
Can I use the following operation when I have disabled nginx inside the container?
DISCOURSE_EXTERNAL_BASE_URL: “https://domain:3443”
Moreover, I found that after users log in, they are automatically redirected to https://domain/latest, and the default port 3443 is not added, causing it to fail to load. At this point, you must manually add https://domain:3443/latest.
Discourse won’t work on port 3443. You have to use 443.
Is this a standard install?
:face_with_peeking_eye:
Thank you for your reply
Yes, I know there are many components hardcoded to port 443. My port 443 is not usable, so I had to switch to port 3443. Currently, many functions are not working. I thought someone had studied this issue
Those who have studied the issue know that it won’t work on a non-standard port. I promise.
It’s pretty well documented, or so I thought.
It seems I have to give up on this huge project
If it’s not worth a $12/month VM or configuring a reverse proxy, then I think you’re right.
Not about cost. Maybe I want to push it a bit further, like installing multiple Discourse instances on one big server
If you want multiple sites then you either need multisite or a reverse proxy. I usually use traefik, but https://hub.docker.com/r/nginxproxy/nginx-proxy is a little easier. Just add some docker labels and it works.
