Is er een manier om DISCOURSE_PORT naast DISCOURSE_HOSTNAME op te geven?
The user is experiencing issues with their Discourse setup, where the DISCOURSE_PORT (9443) is not being recognized despite being specified in the containers/app.yml file. This is causing problems with admin user creation, user registration, and OAuth connections. vsile is looking for a way to specify DISCOURSE_PORT next to DISCOURSE_HOSTNAME. pfaffman suggests that this is a known issue and recommends following the guide on setting up Discourse on a server with existing sites and removing the SSL and Let’s Encrypt templates.
The target URL is https://discourse.example.com:9443.
We use reverse proxy (nginx) on another server with this config:
Спойлер
server {
	listen 9443 ssl;
	listen [::]:9443 ssl;
	client_max_body_size 500m;
	server_name discourse.example.com;
	ssl_certificate /etc/ssl/certs/example.com.pem;
        ssl_certificate_key /etc/ssl/private/example.com.key;
	location / {
		proxy_pass http://10.250.26.133:3080/;
		proxy_set_header Host $host;
		proxy_set_header X-Real_IP $remote_addr;
		proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
		proxy_set_header X-Forwarded-Proto $scheme;
And this containers/app.yml:
Спойлер
templates:
#  - "templates/web.ssl.template.yml"
#  - "templates/web.letsencrypt.ssl.template.yml"
expose:
  - "3080:80"   # http
  - "443:443" # https
params:
  db_shared_buffers: "2048MB"
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  UNICORN_WORKERS: 8
  DISCOURSE_HOSTNAME: discourse.example.com
  DISCOURSE_PORT: 9443 # <- this doesn't work
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'admin@example.com'
  DISCOURSE_SMTP_ADDRESS: smtp.example.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: example-username
  DISCOURSE_SMTP_PASSWORD: "p@ssw0rd"
  DISCOURSE_SMTP_AUTHENTICATION: login
  DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: none
  DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  DISCOURSE_SMTP_DOMAIN: example.com
  DISCOURSE_NOTIFICATION_EMAIL: discourse@example.com
  LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-oauth2-basic.git
run:
I run ./launcher rebuild app.
Then we have working url https://discourse.example.com:9443.
But
  1. I couldn’t create admin user, because Discourse redirects me to URL without 9443 port.
    I had to create admin via console (./launcher enter app and then rake admin:create)
  2. I couldn’t register any other user because the same reason.
  3. I couldn’t connect with Gitea OAuth, because Discourse generates authorize URL with wrong redirect_uri (missed 9443 port in URL)
Is there a way to specify DISCOURSE_PORT next to DISCOURSE_HOSTNAME?
You can’t access discourse on a web browser on a nonstandard port. See How to set up Discourse on a server with existing Apache sites. There is also a similar topic for nginx, but you just need the discourse part so this one should do it for you.
You also need to remove the ssl and let’s encrypt templates. Also, no need to expose 443.
