What is the best way to check the integrity of the database?
סיכום מבוסס בינה מלאכותית
AstonJ is trying to merge data from an older Discourse forum into a fresh install but encounters PG::ForeignKeyViolation errors. They ask if there’s a Discourse tool to check database integrity and suggest such a tool might be useful. AstonJ shares a schema diff between the old and new databases, highlighting missing indexes (e.g., index_badges_on_badge_type_id, index_user_badges_on_user_id, schema_migrations_pkey), a missing sequence (topic_search_data_topic_id_seq), and incomplete topic_search_data table definitions. They seek advice on whether these issues are concerning and if manual fixes are needed, noting it’s late and they’re tired.
I want to merge the users, topics and posts from one forum into another and while the forum restores onto a dev environment without issue, I am getting PG::ForeignKeyViolation errors when trying to merge it (currently into a fresh install)… so wondered whether there is a Discourse tool that can check the integrity of a database? If not, any other tips or ideas?
(There’s also been a few topics about database issues so wondering if this is something the DC team think is worth having if such a tool is not currently available?)
I’ve manually done a diff on schemas from a Discourse forum that was started over 5 years ago and a fresh install, you can see the differences here:
https://www.diffchecker.com/lZrp2jxJ
Mostly changes of bigint to integer and character varying(255) to character varying and a few not nulls missing, but there are some indexes missing too.
Here are the lines that point them out:
Line 1646 - missing:
  Index "public.index_badges_on_badge_type_id"
 Column |          Type          | Key? | Definition 		    Column     |  Type   | Key? |  Definition
 name   | character varying(255) | yes  | name		 badge_type_id | integer | yes  | badge_type_id
btree, for table "public.badges"
3301 - missing:
	Index "public.index_user_badges_on_user_id"
 user_id | integer | yes  | user_id
btree, for table "public.user_badges"
4639 - missing:
	      Index "public.schema_migrations_pkey"
 version | character varying | yes  | version
primary key, btree, for table "public.schema_migrations"
5487 - partly missing:
                                       Table "public.topic_search_data"
   Column    |          Type          | Collation | Nullable | Default 		   Column    |       Type        | Collation | Nullable |                       Default
 topic_id    | integer                |           | not null | 		 topic_id    | integer           |           | not null | nextval('topic_search_data_topic_id_seq'::regclass)
 raw_data    | text                   |           |          | 		 raw_data    | text              |           |          |
 locale      | character varying(255) |           | not null | 		 locale      | character varying |           | not null |
 search_data | tsvector               |           |          | 		 search_data | tsvector          |           |          |
 version     | integer                |           |          | 0		 version     | integer           |           |          | 0
5506 - missing:
           Sequence "public.topic_search_data_topic_id_seq"
  Type   | Start | Minimum |  Maximum   | Increment | Cycles? | Cache
 integer |     1 |       1 | 2147483647 |         1 | no      |     1
Owned by: public.topic_search_data.topic_id
6044 - missing:
    "index_user_badges_on_user_id" btree (user_id)
Should I be concerned about anything here? Should I add the indexes manually? Any other thoughts or anything else stand out to anyone (it’s nearly 5am here and I’m struggling to keep my eyes open :see_no_evil:)
