What is the bug reporter badge?
Oh, sorry, I didn’t look at the context the query was being used in. You’ve currently got something like this:
WHERE category_id = (
  SELECT id FROM categories
  WHERE name IN ('OAuth', 'Developers')
Since the inner query is returning multiple rows, you need to change the outer WHERE clause to:
WHERE category_id IN (
Success, thanks!
Would this be too much to run whenever a user acts on a post?
Could it easily be modified to award a badge when a post is ‘marked as a solution’ rather than liked?
edit: Actually, that’s giving me: ‘Contract violation: Query triggers on posts, but does not reference the ‘:post_ids’ array’
I can probably live with update daily though. ¯_(ツ)_/¯
@sam, we’re looking on implementing a similar badge over at Stonehearth. Can you share the current SQL used, as yours is 2+ years old, and there are numerous different versions in this topic?
Bug Reporter
SELECT distinct p.user_id, p.created_at granted_at, p.id post_id
FROM badge_posts p
JOIN topics t ON t.id = p.topic_id
JOIN post_actions pa ON pa.post_id = p.id AND
      post_action_type_id = (
                SELECT id FROM post_action_types WHERE name_key = 'like'
       ) AND
       pa.user_id IN (
           SELECT gu.user_id
           FROM group_users gu
           WHERE gu.group_id = ( SELECT id FROM groups WHERE name ilike 'team' )
  SELECT id FROM categories WHERE name ilike 'bug'
) AND p.post_number = 1
Tech Support
SELECT id user_id, current_timestamp granted_at
FROM users
WHERE id  IN (
       SELECT p1.user_id
       FROM post_custom_fields pc
       JOIN badge_posts p1 ON p1.id = pc.post_id
       JOIN topics t1 ON p1.topic_id = t1.id
       WHERE p1.user_id <> t1.user_id AND
                    name = 'is_accepted_answer' AND
            p1.user_id IN (
                   SELECT user_id
                   FROM posts
                   WHERE :backfill OR  p1.id IN (:post_ids)
        GROUP BY p1.user_id
        HAVING COUNT(*) > 9
Tester
SELECT p.user_id, MIN(p.created_at) granted_at
  FROM posts p
 WHERE t.category_id = (SELECT id FROM categories WHERE name ILIKE 'bug')
   AND EXISTS (
         SELECT 1
           FROM post_actions pa
          WHERE pa.post_id = p.id
            AND pa.post_action_type_id = (SELECT id FROM post_action_types WHERE name_key = 'like')
            AND pa.user_id IN (SELECT user_id FROM group_users WHERE group_id = (SELECT id FROM groups WHERE name ILIKE 'team'))
 GROUP BY p.user_id
HAVING COUNT(*) >= 10
Senior Tester
  FROM posts p
   AND EXISTS (
         SELECT 1
 GROUP BY p.user_id
HAVING COUNT(*) >= 20
I was just awarded the Tester badge, but I only have 2 Bug Reporter badges. The text of the Tester badge says this:
grafik
Reported 10 bugs that were liked by the Discourse team
I just checked: One of my bug reports has 10 :heart: likes, but not even those are exclusively by Discourse Team members.
Something seems to be wrong with the badge… :thinking:
There are several old bugs that were deleted as not of future historical interest, but the total isn’t 10.
Thanks, I fixed the queries and updated @sam’s post.
@sam where should i run this code to have this badge assign, and should we create a category for bug report ?
  FROM posts p
   AND EXISTS (
         SELECT 1
 GROUP BY p.user_id
This badge is specific to meta.
Ahhh, we cant use it in discourse ?
Yes, we can. But category and group names must be changed to valid ones.
Understood, like hiding the category trick, but here i didn’t recogniz where to run sam code; from admin panel or inside container rails c ?
You might not be finding where you can add the code because editing badge SQL editing is now disabled by default. See here:
So I think the process would be to:
  1. Enable badge SQL editing (instructions in the linked topic)
  2. Create a new badge in Admin > Badges (or edit an existing badge if you’ve already created it)
  3. Add your SQL to the badge and save
  4. Disable badge SQL editing
Then if you haven’t already done so, going by the values in the SQL you posted:
  1. Create a category called “bug”
  2. Create a user group called “team”
  3. Add the users that you want to be able to accept bug reports to “team”
This may be an improvement for the query :slight_smile:
WITH LikeActionTypes AS (
    SELECT id
DiscourseGroup AS (
    SELECT id
    FROM groups
    WHERE name ILIKE 'discourse'
BugCategory AS (
    SELECT id
    FROM categories
SELECT
    p.user_id,
    MIN(p.created_at) AS granted_at,
    MIN(p.id) AS post_id
FROM badge_posts AS p
LEFT JOIN topics AS t ON t.id = p.topic_id
LEFT JOIN post_actions AS pa ON pa.post_id = p.id
LEFT JOIN LikeActionTypes AS lat ON pa.post_action_type_id = lat.id
LEFT JOIN group_users AS gu ON pa.user_id = gu.user_id
LEFT JOIN DiscourseGroup AS dg ON gu.group_id = dg.id
LEFT JOIN BugCategory AS bc ON t.category_id = bc.id
WHERE p.post_number = 1
GROUP BY p.user_id;
