The discussion revolves around granting access to the Discourse WordPress settings page (https://site.com/wp-admin/admin.php?page=wp_discourse_options) to a developer without admin rights. RickU seeks the required WordPress capability, and Arkshine identifies manage_options as the needed capability based on the plugin’s code. tariqkotwal suggests two solutions: using plugins like User Role Editor and Adminimize to create a custom role with limited access, or adding custom code to allow access without full manage_options privileges. RickU appreciates the suggestions and plans to test them. jrgong raises a similar concern, noting the overhead of granting full access and hiding elements, especially in a lightweight setup. angus asks for examples of plugins with role-based admin access to improve functionality. jrgong clarifies their use case: instructors in a LearnDash LMS setup need access to Discourse settings for content posting but currently lack it.
There are 2 ways to allow your developer to have access to this page, one is
Step 1: Install User Role Editor Plugin and create a custom role for your developer and assign manage_options capability, but this will also allow him to have access to admin related menus like settings, etc, so to avoid that, install Adminimize Plugin and remove admin menus for that particular role
Step 2: Create a user with the new role you have created and share the credentials with your developer.
Another is, add a custom code in your theme / child theme (if child theme is active) which will allow you to set custom capability for the Discourse admin menu access, create a custom role using code and assign the new capability to the role and create a user with the custom role and share the credentials with your developer, but in this method your developer can only see the page but can’t edit/update/save any changes, since manage_options capability is not provided which is required to save options in WordPress. If you want I can add the code on github and share the link here.
I will be taking a look at this solution. It seem simple. I have been doing a lot of updates to our side and schedule has been crazy. I will update of the out come or route taken.
The access situation remains the same as discussed above.
Do you have an example of a plugin that uses role-based access to its admin panel that you like, i.e. along the lightweight lines you suggested? I’m interested in improving this kind of functionality and would like to canvas pain points / desired functionality.
In our use case, we are using Learndash LMS and using WP Discourse to post their custom post types lesson and topic into our forum. It has their own instructor roles. While instructors can edit the content, they don’t have access to WP discourse panel.
