What will be the proper way to troubleshoot the errors?
Hello everyone,
I have to support the discourse server where I see the error in the log below. What will be the correct approach to fix that error? The version is 3.3.0.beta1.
Thanks
app/views/layouts/application.html.erb:10
actionview (7.0.8.1) lib/action_view/base.rb:244:in `public_send'
actionview (7.0.8.1) lib/action_view/base.rb:244:in `_run'
actionview (7.0.8.1) lib/action_view/template.rb:157:in `block in render'
activesupport (7.0.8.1) lib/active_support/notifications.rb:208:in `instrument'
actionview (7.0.8.1) lib/action_view/template.rb:361:in `instrument_render_template'
actionview (7.0.8.1) lib/action_view/template.rb:155:in `render'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionview (7.0.8.1) lib/action_view/renderer/template_renderer.rb:76:in `block in render_with_layout'
activesupport (7.0.8.1) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.0.8.1) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (7.0.8.1) lib/active_support/notifications.rb:206:in `instrument'
actionview (7.0.8.1) lib/action_view/renderer/template_renderer.rb:74:in `render_with_layout'
actionview (7.0.8.1) lib/action_view/renderer/template_renderer.rb:59:in `render_template'
actionview (7.0.8.1) lib/action_view/renderer/template_renderer.rb:11:in `render'
actionview (7.0.8.1) lib/action_view/renderer/renderer.rb:61:in `render_template_to_object'
actionview (7.0.8.1) lib/action_view/renderer/renderer.rb:29:in `render_to_object'
actionview (7.0.8.1) lib/action_view/rendering.rb:117:in `block in _render_template'
actionview (7.0.8.1) lib/action_view/base.rb:270:in `in_rendering_context'
actionview (7.0.8.1) lib/action_view/rendering.rb:116:in `_render_template'
actionpack (7.0.8.1) lib/action_controller/metal/streaming.rb:216:in `_render_template'
actionview (7.0.8.1) lib/action_view/rendering.rb:103:in `render_to_body'
actionpack (7.0.8.1) lib/action_controller/metal/rendering.rb:158:in `render_to_body'
actionpack (7.0.8.1) lib/action_controller/metal/renderers.rb:141:in `render_to_body'
actionpack (7.0.8.1) lib/abstract_controller/rendering.rb:27:in `render'
actionpack (7.0.8.1) lib/action_controller/metal/rendering.rb:139:in `render'
actionpack (7.0.8.1) lib/action_controller/metal/instrumentation.rb:22:in `block (2 levels) in render'
/usr/local/lib/ruby/3.2.0/benchmark.rb:311:in `realtime'
activesupport (7.0.8.1) lib/active_support/core_ext/benchmark.rb:14:in `ms'
actionpack (7.0.8.1) lib/action_controller/metal/instrumentation.rb:22:in `block in render'
actionpack (7.0.8.1) lib/action_controller/metal/instrumentation.rb:91:in `cleanup_view_runtime'
activerecord (7.0.8.1) lib/active_record/railties/controller_runtime.rb:34:in `cleanup_view_runtime'
actionpack (7.0.8.1) lib/action_controller/metal/instrumentation.rb:21:in `render'
lib/topic_list_responder.rb:15:in `block (2 levels) in respond_with_list'
actionpack (7.0.8.1) lib/action_controller/metal/mime_responds.rb:214:in `respond_to'
lib/topic_list_responder.rb:8:in `respond_with_list'
app/controllers/list_controller.rb:111:in `block (2 levels) in <class:ListController>'
actionpack (7.0.8.1) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.0.8.1) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack (7.0.8.1) lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:118:in `block in run_callbacks'
app/controllers/application_controller.rb:1102:in `add_link_header'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:127:in `block in run_callbacks'
app/controllers/application_controller.rb:423:in `block in with_resolved_locale'
i18n (1.14.4) lib/i18n.rb:322:in `with_locale'
app/controllers/application_controller.rb:423:in `with_resolved_locale'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack (7.0.8.1) lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/rescue.rb:23:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
actionpack (7.0.8.1) lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.0.8.1) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (7.0.8.1) lib/abstract_controller/base.rb:151:in `process'
actionview (7.0.8.1) lib/action_view/rendering.rb:39:in `process'
actionpack (7.0.8.1) lib/action_controller/metal.rb:188:in `dispatch'
actionpack (7.0.8.1) lib/action_controller/metal.rb:251:in `dispatch'
actionpack (7.0.8.1) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.0.8.1) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.0.8.1) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (7.0.8.1) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (7.0.8.1) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.0.8.1) lib/action_dispatch/routing/route_set.rb:852:in `call'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack (2.2.9) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.9) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.9) lib/rack/head.rb:12:in `call'
actionpack (7.0.8.1) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
lib/middleware/anonymous_cache.rb:391:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
rack (2.2.9) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.9) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack (7.0.8.1) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/show_exceptions.rb:29:in `call'
logster (2.19.1) lib/logster/middleware/reporter.rb:40:in `call'
railties (7.0.8.1) lib/rails/rack/logger.rb:40:in `call_app'
railties (7.0.8.1) lib/rails/rack/logger.rb:27:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/request_id.rb:26:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
rack (2.2.9) lib/rack/method_override.rb:24:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.9) lib/rack/sendfile.rb:110:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:191:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
lib/middleware/request_tracker.rb:236:in `call'
railties (7.0.8.1) lib/rails/engine.rb:530:in `call'
railties (7.0.8.1) lib/rails/railtie.rb:226:in `public_send'
railties (7.0.8.1) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.9) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.9) lib/rack/urlmap.rb:58:in `each'
rack (2.2.9) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
How was discourse installed?
Are you using discourse connect for authentication?
It was a Discourse Droplet.
