Buonasera,
Ho installato con successo oggi sul mio cluster Kubernetes - Discourse.
Finora tutto ha funzionato bene, ma ho il problema che Discourse non viene visualizzato correttamente.
Cosa sto sbagliando?
Ho installato l’immagine bitnami
Grazie!
Ecco il Log:
discourse 20:59:40.11 INFO == Precompiling assets, this may take some time...
discourse 21:01:25.15 INFO == ** Discourse setup finished! **
discourse 21:01:25.18 INFO == ** Starting Discourse **
=============== Phusion Passenger(R) Standalone web server started ===============
PID file: /opt/bitnami/discourse/passenger.8080.pid
Log file: /opt/bitnami/discourse/log/passenger.8080.log
Environment: production
Accessible via: http://0.0.0.0:8080/
You can stop Phusion Passenger(R) Standalone by pressing Ctrl-C.
Problems? Check https://www.phusionpassenger.com/library/admin/standalone/troubleshooting/
[ N 2022-03-04 21:01:32.0224 385/T5 age/Cor/SecurityUpdateChecker.h:519 ]: Controllo aggiornamenti di sicurezza: nessun aggiornamento trovato (prossimo controllo tra 24 ore)
Started HEAD "/" for 127.0.0.1 at 2022-03-04 21:01:55 +0000
Processing by ListController#latest as HTML
Rendered list/list.erb within layouts/crawler (Duration: 33.3ms | Allocations: 10472)
Rendered layout layouts/crawler.html.erb (Duration: 201.9ms | Allocations: 32399)
Completed 200 OK in 1116ms (Views: 209.7ms | ActiveRecord: 0.0ms | Allocations: 194757)
Started GET "/" for 127.0.0.1 at 2022-03-04 21:03:26 +0000
Rendered list/list.erb within layouts/application (Duration: 4.3ms | Allocations: 787)
Rendered layout layouts/application.html.erb (Duration: 308.9ms | Allocations: 83557)
Completed 200 OK in 657ms (Views: 312.5ms | ActiveRecord: 0.0ms | Allocations: 140796)
Started GET "/discoutse" for 127.0.0.1 at 2022-03-04 21:03:31 +0000
ActionController::RoutingError (No route matches [GET] "/discoutse")
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/request_tracker.rb:198:in `call'
Rendered exceptions/not_found.html.erb within layouts/no_ember (Duration: 2.5ms | Allocations: 630)
Rendered layout layouts/no_ember.html.erb (Duration: 27.8ms | Allocations: 4067)
Rendered html template (Duration: 0.0ms | Allocations: 2)
Started GET "/discourse" for 127.0.0.1 at 2022-03-04 21:03:35 +0000
ActionController::RoutingError (No route matches [GET] "/discourse")
Rendered exceptions/not_found.html.erb within layouts/no_ember (Duration: 0.8ms | Allocations: 139)
Rendered layout layouts/no_ember.html.erb (Duration: 21.7ms | Allocations: 2371)
[ N 2022-03-04 21:08:38.9746 385/T4 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 565, application /opt/bitnami/discourse (production)
[ N 2022-03-04 21:08:39.0662 385/T4 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 469, application /opt/bitnami/discourse (production)
[ N 2022-03-04 21:08:49.3180 385/T4 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 617, application /opt/bitnami/discourse (production)
Sebbene Discourse sia un software libero e open source, offriamo supporto gratuito solo per installazioni di produzione che seguono la nostra guida ufficiale all’installazione.
Poiché stai utilizzando un pacchetto fornito da bitnami, dovrai utilizzare i loro canali di supporto per questa installazione, poiché non è qualcosa che il team di Discourse ha creato.
