Specifically, I’m looking for total posts, total topics.
The about page only shows the past 7 days. Is the only way now to manually pull it from reports:
thanks
thanks
I believe that this update revamped the about page to be for only 7 days of length: New and improved About page at /about is live
Before, it used to look like this:
From my knowledge you can still pull data from reports.
Go to Admin and click the Reports button (you can also use the sidebar):
yes, seems to be only available by manually pulling now.
Yup, either Reports or you could use Data Explorer.
Also available in JSON format: /about.json
