איפה "top" בתצוגות קטגוריה?
Hello,
Filtering topics in a category to see the top in a time period seems to have disappeared:
Am I missing something? I can’t see it anywhere!
Many thanks in advance!
I think it is related to your theme. When I disable themes in safe mode the top link is there
Thank you, that is so odd, I can’t see how a theme could disable it? I’ve looked in settings and it’s there in category desktop view.
The theme you’re using seems to hide the navigation buttons with CSS.
The theme code is overriding the setting and hiding it, as @Arkshine’s screenshot shows. There seems to be fair a bit of customization in that theme and whoever did it definitely hid the nav bar on purpose.
