darkrasid
(Darkrasid)
1
Hi, I try to install discourse v1.7.0.beta10 version.
There are some reason that I can’t use docker which discourse offer.
so I try to install from source directly.
I have base ubuntu which installed discourse v1.6.4 before and I reuse this one.
But I get this error when I try to db migrate.
TypeError: no implicit conversion of nil into String
I guess it is because of ruby or postgres version.
On my ubuntu, I use
ruby : 2.3.0
postgres: 9.4
Is there any specific version do I have to use?
Falco
(Falco)
Even when not using the supported install, you should take a look at it to see what it uses.
We are using PostgreSQL 9.5 currently.
pfaffman
(Jay Pfaffman)
3
You might try starting with the development environment install instructions and then try to switch to production mode.
darkrasid
(Darkrasid)
4
This is awesome!! Thank you.
I could set my ubuntu follow this dockerfile.
