Hi, I’m forced to use an unsupported installation from “scratch” on a RHEL8 system (it’s complicated), and I’m wondering which Ruby version I should use with the current Discourse release?
root@starzen-app:/var/www/discourse# ruby -v
ruby 3.2.2 (2023-03-30 revision e51014f9c0) +YJIT [x86_64-linux]
Source code is your friend:
Great! Was about to follow up asking about Redis, but the link you gave solved that of course ![]()
