Whitelisting HTML tags
yaxu is trying to whitelist the strudel-repl HTML tag in order to embed a musical REPL in their Discourse forum. After some research, they found an example in the discourse-mermaid plugin. JammyDodger suggested looking into the whitelist for the <mark> tag as a possible reference. yaxu has found a temporary solution and accepted their own answer.
I’d like to embed a musical REPL (i.e., the musical live coding editor here: https://strudel.tidalcycles.org/) in my discourse forum.
This is a case of including a little bit of javascript and whitelisting a html tag strudel-repl. I’m struggling with the latter.
I found this thread, which (digging into git history) points at this line.
Searching for helper.whiteList turns up a lot of old examples, but I somehow couldn’t find a clear example for using it in a simple plugin.
Does someone have some pointers for how to whitelist html tags?
Pardon me for the noise, a bit more searching and I found this recent plugin that looks like a perfect example for what I’m trying to do:
GitHub - unfoldingWord/discourse-mermaid: Adds the Mermaid JS library to discourse · GitHub
I remember the <mark> tag being whitelisted a while back:
Hopefully, that can give you some hints or clues while you wait for some more knowledgeable replies. :crossed_fingers::slight_smile:
Thanks, I accepted my own answer for now :slight_smile:
