Bathinda
(Bathinda Helper)
28 oktober 2023 om 10:52
1
My web_only.yml clearly has parameters set as/for: Tests-Passed builds.
But still my website’s Admin dashboard shows: beta3-Dev build.
‘Dev’ word is still there, even after rebuilding my container just now,nothing changed.
I’d rather like to stay with ‘Tests-Passed’ builds.
Jagster
(Jakke Flemming)
28 oktober 2023 om 11:01
AFAIK you are. It could be because of this:
tests-passed
It includes features and improvements from the main channel that have undergone a certain level of testing. It has the best balance between stability and access to the latest improvements.
It is not much different than most other software releases out there, which usually release small changes every two weeks. We commit new changes almost daily instead, and they’re available via tests-passed .
pfaffman
(Jay Pfaffman)
28 oktober 2023 om 11:55
3
A month or so ago they started adding dev to the version to indicate that the version you see doesn’t necessarily mean the beta query that version. I think there was an announcement, but I but can’t find it in the add link modal.
system
(system)
gesloten
27 november 2023 om 11:58
6
