Why does the `SiteSettings` class use the `DistributedCache` without a `require 'distributed_cache';` statement?
What particular issue is this causing?
If I use require 'site_setting_extension' in my plugin, then I need to remember to add require 'distributed_cache' before.
The trouble is that now you are initializing site settings earlier than when the app does.
Can you post the exact code of what you are trying to achieve.
I use SiteSettingExtension.module_eval in my plugins to add custom site setting types, e.g.:
SiteSettingExtension.module_eval do
	alias_method :core__types, :types
	def types
		result = @types
		if not result
			result = core__types
			result[:paypal_buttons] = result.length + 1;
		return result
