Why is the system’s default avatar in a temporary folder “Rails.root/tmp/avatar_proxy”, so that each build after will have a large number of avatar requests. Users often do not upload custom avatars after registration. so I wanted to mount this folder as a normal folder in case I get a lot of avatar requests with each build. Are there any problems with this? Thanks
נושאים קשורים
| נושא | תגובות | צפיות | פעילות | |
| Discourse /tmp/avatar_proxy folder | 0 | 33 | 10 בספטמבר, 2024 | |
| How are avatars stored and accessed? | 7 | 1986 | 8 ביוני, 2024 | |
| Problems with avatar uploads due to S3 changes | 22 | 3444 | 27 באוקטובר, 2018 | |
| Only showing the default avatar? | 4 | 1202 | 8 ביוני, 2024 | |
| Avatars became default after 2.2 beta upgrade - due to regression in azure blob plugin | 20 | 1490 | 9 בפברואר, 2019 |
