Discourseコードベースのコードコメントがなぜこれほど少ないのか?(GitHub)
https://github.com/discourse/discourse
Background
I was trying to customize Discourse.
(deep customization, theme/plugin is not enough, not a simple facelift change(logo, color, image etc))
I git clone to my laptop and start reading the code.
(I am Ruby on Rails dev & newbie Ember.js dev)
Question
  1. Why there are so little code comment in codebase?
    (controller / model / view / etc, both Rails and Ember)
I get the phrase “good code itself is comment” (or something like that)
But why so little?
Thanks.
Because comments tend to rot and deprecate which makes them useless (and sometimes counter intuitive) over time.
「いいね!」 6
Thanks for reply
But 1-4 line comment per-controller/view/template/etc seem like reasonable number.
not too much, not too little
:smile:
I hope you guys(Discourse core team) can write few post about the
big picture view on Discourse codebase…
(not like “why chose Ember.js” I already read that one. deeper than that)
like:
  1. Why this folder structure(Ruby on Rails & Ember.js put together)
    I guess if you guys make Discourse from scratch in 2018,
    would decide separated Rails&Ember into 2 repo?
    or different folder structure
  2. What’s the different between GlobalSetting & SiteSetting?
  3. What’s the core model of Discourse? (Users&Post&Topic)?
  4. why preload_script is needed? example <%= preload_script 'break_string' %>
    preload_script return
# ... some other code
<link rel='preload' href='#{path}' as='script'/>
<script src='#{path}'></script>".html_safe
so it’s for SEO or some other reason?
  1. and few other question I couldn’t recall right now
「いいね!」 1
You can/should use plugin.
「いいね!」 4
OK, I would read more into plugin.
Thanks for the suggestion Vinoth Kannan
Unless you have a team of full time programmers or want never to take advantage of future upgrades to discourse, you want a plugin. Those who have forked are all sorry.
Almost anything can be accomplished with a plugin.
「いいね!」 8
Got it, Thanks!
we do want future upgrade, would look into Theme and Plugin.
Thanks for reply!
「いいね!」 2
