Why vbulletin 4 importer exclude the firstpost?
Why the importer in vbulletin exclude the firstpost from the total_count?
Most likely because the first post is used to create the topic.
But then if I have ten topic/thread with attachment just in the first post, the total_count will be zero, even though I have ten attachments. right?
Hmm, I didn’t look closely enough. Looks like you’re right :wink:
PRs are welcome :smile:
Ok.
While we at it, this line cause errors:
I had to modified it just like the vb5 importer:
What was the error? Did it try creating an already existing index?
Yes I did. I get the error after the second run.
ref:
https://meta.discourse.org/t/vbulletin-importer-fails/26120
Probably want to handle that better rather than just catching the exception :wink:
