Trabajando en el primer plugin; no funciona. Usando el plugin pirate-speak como base
Here is the repository for it. My wife tried using it to no avail. It does not convert the text to an image. Either that, or this plugin I based it off from cannot change some text e.g. [m08] (meaning, major arcana number 8) into an image:
I would have her use the built-in custom emoji uploader but it shrinks the image; undesired. Any helps are appreciated.
Just edited the regex rules and it still does not work. The regex was wrong for this usage case. Left out the word boundaries.
I installed the pirate speak plugin to see if I screwed up anywhere. That plugin does not work either.
Is anyone willing to update the pirate speak plugin. According to a google search, it shall be relevant on the 19th. Arrrh. :pirate_flag:
https://github.com/discourse/discourse-pirate-speak
I’d guess that today that would rather get turned into a theme component; it doesn’t actually need to be a plugin, because it has no server-side logic. Likely same for your tarot project; I don’t think it needs to actually be a plugin.
This particular example still requires a plugin, cause it is a markdown dialect and processed server side.
Pirate speak though is in “broken plugin” state at the moment as it still needs to be updated to markdown.it … adding a note.
