Problema con la actualización forzada de avatar en SSO de WP Discourse
Hi,
I use Wordpress as SSO provider with WP Discourse plugin. Users register site on the Wordpress system. SSO works fine. But i want to use WP Discourse’s force avatar update feature. When user registers Wordpress system and update avatar Discourse avatars update on the first login. But the second time the avatar is changed on Wordpress system Discourse avatar not sync with Wordpress avatar.
What could be the problem? Any idea?
** When logout and login again it’s updated.
That makes sense. For Discourse to get the new avatar URL will require the user to go through the SSO login process. I don’t think there is much that can be done to fix this.
