Slowhand
(Slowhand)
1
I did a search but got hundreds of results, I did look for quite a while.
Our forum does not the option to change from white to grey or dark, so it’s blindingly white all the time.
Recently, the Wrench Tools & Post Options menus went from a grey color to completely white also.
Is there an easy fix to put that color back in?
Before & after screenshot:
Hello,
This is all intentional and if you are on 2.5.0 beta 6 you will have noticed these changes. A bit of CSS should help you here
Slowhand
(Slowhand)
3
Thank you.
Could you please tell me how to go about changing this? Is it an Admin-type fix, or something you guys do from your end?
Well, you’d target those HTML element classes in Admin, Customize and change them however you see fit using CSS rules.
Slowhand
(Slowhand)
5
Thank you for all your help, we’ve taken care of it. Really appreciate you all!
