while running the auto install script, it gave me an error message:
(): did not find expected key while parsing a block mapping at line 42 column 3 -e LANG=en_US.UTF-8
YAML syntax error. Please check your containers/*.yml config files.
as i believe this is a docker container (i think), i dont know how to locate the file to fix the problem. I’m sorry as im not familiar with linux, docker, or programming in general… please help
Yeah, really strange. Because I get similar when trying to rebuild web_only of 2-container.
did not find expected key while parsing a block mapping at line 4 column 1 -e LANG=en_US.UTF-8
There is only one problem. I don’t use en_US, I’m using fi_FI.UTF-8.
Edit
This is unbelivable I had two one space long errors: one where I told S3 and one before a plugin. At least one hour wasted… when I learn those error notifications are almost everytime wrong.
