Yandex Translation Service
Hi,
At the moment, only Microsoft and Google services are supported on the plugin, which both are paid services. However, Yandex provides a free translation API, which could be really useful used in Discourse forums.
I started modifying the plugin to add its support, but I am stuck here:
https://github.com/barreeeiroo/discourse-translator/commit/3ef433473a7314b580a63fc8c8794e219899ddc4
Any idea of what am I missing? The translation button does not appear in posts.
Tested a post in Spanish, with both Discourse and Profile locale in English
naive guess, but maybe you did not enable the plugin in side settings? maybe there is a hardcoded check for either google or ms keys?
Yeah, I did
And also inputted my Yandex API Key
I searched for Microsoft and Google references in the plugin, and I think I’ve already modified all of them
BTW, is there a way to print to the console from a plugin? :sweat_smile:
I would like to check which piece of code gets executed
In development, you can use puts to print to your console
If you want to print something to /logs, then
Rails.logger.warn("Message to log")
Well, after so much trial and error… :smile:
I got it working!
Will submit a PR after polishing the last details
Hello,
Thanks for this contribution :slight_smile:
Just a question, it’s marked as merged, but the doc does not mention it, what is the current status of Yandex translator in the T++ plugin?
Just to round this out, I believe Yandex is currently one of the supported services:
