Your connection to this site is not fully secure
Any ideas how to fix this? I see that the schema.org urls are going through http protocol, could this be the problem? URL of my forum is wmforum.geek.hr
Hi @steelmaiden
no, that’s not the problem. These are internal definitions
<script type="application/ld+json">{"@context":"http://schema.org","@type":"WebSite","url":"https://wmforum.geek.hr","potentialAction":{"@type":"SearchAction","target":"https://wmforum.geek.hr/search?q={search_term_string}","query-input":"required name=search_term_string"}}</script>
like namespace definitions, not urls used to load the content.
I don’t see mixed content warnings.
Use Ctrl + Shift + I, then check the console to find the urls.
Got this:
Refused to load the script 'https://certify-js.alexametrics.com/atrk.js' because it violates the following Content Security Policy directive: "script-src https://wmforum.geek.hr/logs/ https://wmforum.geek.hr/sidekiq/ https://wmforum.geek.hr/mini-profiler-resources/ https://wmforum.geek.hr/assets/ https://wmforum.geek.hr/brotli_asset/ https://wmforum.geek.hr/extra-locales/ https://wmforum.geek.hr/highlight-js/ https://wmforum.geek.hr/javascripts/ https://wmforum.geek.hr/plugins/ https://wmforum.geek.hr/theme-javascripts/ https://wmforum.geek.hr/svg-sprite/ https://www.google-analytics.com/analytics.js https://cdn.jsdelivr.net/npm/cookieconsent@3/build/cookieconsent.min.js". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
and this:
Refused to load the script 'https://script.dotmetrics.net/door.js?id=1249' because it violates the following Content Security Policy directive: "script-src https://wmforum.geek.hr/logs/ https://wmforum.geek.hr/sidekiq/ https://wmforum.geek.hr/mini-profiler-resources/ https://wmforum.geek.hr/assets/ https://wmforum.geek.hr/brotli_asset/ https://wmforum.geek.hr/extra-locales/ https://wmforum.geek.hr/highlight-js/ https://wmforum.geek.hr/javascripts/ https://wmforum.geek.hr/plugins/ https://wmforum.geek.hr/theme-javascripts/ https://wmforum.geek.hr/svg-sprite/ https://www.google-analytics.com/analytics.js https://cdn.jsdelivr.net/npm/cookieconsent@3/build/cookieconsent.min.js". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
Those are tracking scripts, i need them to run properly.
If I’m not wrong, you likeky need to add those scripts in content security policy script src.
These are not mixed content warnings.
These are other problems you should fix.
Mixed content warnings: Images via http.
