My banner works fine. Just added a youtube video and it appears embedded on a regular page but the banner only doesnt show the youtube box at all.
Do I have to embed the raw youtube code instead?
Hmm, yeah, embeds are not really supported in the banner. We’d have to think of enhancing the feature.
I worked around it by customising my html with a bit of jquery to inject a youtube embed code:
So in the custom header:
<script>
function readyFn( jQuery ) {
// check if sign up button showing
if ( $('.sign-up-button').length ) {
$('#banner-content').prepend("<div style='float:right; margin:0 auto'><iframe src='https://www.youtube.com/embed/ou6uUpu7Fy8?autoplay=0&rel=0&showinfo=0' frameborder=\"0\" allowfullscreen></iframe></div>");
// when the entire window loads up:
$( window ).load( readyFn );
Only thing is the jquery only runs on the first load of the site so video disappears if you navigate to any of the topics
If you use this plugin you can add a Youtube iframe to the banner post:
https://github.com/scossar/whitelist-iframe
