Browse Channels: Sort Channels in Alphabetic Order?
In chat, your joined channels appear in alphabetic order in the sidebar as expected but if browse for other channels to join there does not appear to be any rhyme or reason to how the channels are organized.
Is there any way to sort these in alphabetic order? We’re going to be adding lots of channels so this would be very helpful. Thanks.
I don’t think there is. I do think that it is sorted based on when it was created (I.e. oldest to newest).
For example, I created “MSFS Discussion” then “HFS” then “Admin team” and it is in the order that I made them in.
(“General” and “Staff” are defaults)
I can recommend you create the new channels
starting with the first channel in the alphabet (that is, if you needed to make channels “cookie” “apple” and “banana”, create “apple” first then “banana” and so on.)
Hope this helps :slight_smile:
